Hi Guys and Girls.
Whilst cleaning up my shed, I found these:
Whiteline KLS125 Swaybar Links. These came with my BNR11XXZ GTR Swaybar a long time ago, but I never used them as I bought the rose joint ones instead.
I believe they are a Universal item and will suit most Nissan Rear Swaybars..
Looking for $40 o.n.o
Can post for $8 anywhere in Australia
Nigel
Hope Valley SA
