Hi people, just wanting to hear peoples thoughts on High Octane coatings. I have used Competition Coatings, HPC, Jet Hot in the past and have my thoughts on the respective pros and cons of them....I have not used High Octane coatings in the past.
Anyone used their black manifold/turbine housing coating and can speak to its durability?
http://www.performancecoating.com.au/turbocharger-coating
My own experience has HPC the best for quality and durability...no surprise they are they most expensive. Competition Coatings and Jet Hot about the same, with perhaps Jet Hot being a tad more durable but less range of colours and finishes.
I've used Techline ceramic coatings on my manifolds and turbine housings on 2 of my cars. Coatings are inside and out of the manifolds and turbine housings.
I've proven the coatings hold up to sustained heat around 850 degrees no problems. Looks good too. I don't know who of the companies you mentioned use the techline products, but the key is in the application. I have an aluminium oxide/ceramic base under the black TurboX coating.
Competition Coatings did a set of CP pistons for me in one of my other engines. The finish looked great. Never produced any performance data with that engine though. Changed the recipe before getting that far.
I used a local ceramic coating a few years back. The ceramic held up but i swear the black that i paid extra for was just heat proof paint. After tuning on the dyno the black was peeling off from the collector.
ive used competition coating for my manifold and turbine housing, the high temp black one,
seems to have reduced my coolant temperature a fair bit , could be the larger turbo contributing though, seems ok so far.. not fancy to look at though, just faded black looking..
craved coatings did mine too, after a couple of dyno pulls the exhaust housing was measuring 300c on the surface (manifold and housing ceramic coated a cast iron/gunmetal grey colour inside and out)
competition coatings did both my manifolds, both sides of my turbo, cooler piping, TB and dump pipe.... looks sick and works really well... Ive got a few lines which are really close to my dump pipe and im so supprised that they havnt melted... without the coating im sure they would have.
All encouraging, but how long have you been running the manifold, turbine housing coatings. This ca is driven around 1000kms a month and does some sustained wide open throttle stuff so will get plenty of heat in it doing some fun days at the track. I have decided will be givign Comp Coating a go in Coburg and see how they go
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
