Is It Ok To Run No Lower And Upper Timing Covers
If this was an industrial application (and more so, an equipment/health safety thing) then I'd be mooting a 2 out of 3 voting system. You have 3x sensors, expect and want all 3 of them to agree, but in the event of disagreement of one of them, you use the agreed value of the other 2. And raise a fault. This then places the common failure mode on whatever linkage you have connecting the 3 sensors to the thing that moves, but some common sense can be applied to make that similarly redundant, space being available, of course.
Oh righto, Brad is always banging on about the gear pos sensor and how critical it is. Better than rusty actuator like a holinger
Dunno. Seeing as you can get something essentially the same, brand new, for the same moneys? https://www.supercheapauto.com.au/p/motorkool-external-trans-oil-cooler/SPO442465.html#q=oil%2Bcooler&lang=en_AU&start=49
Hey @Rich-K What time are you planning on meeting at Ourimbah RSL? Might be able to add a stop in the SAU Old Pac Cruise to join up together for the rest of the drive up, depending on times. Thanks
