Hey Guys
Just some stuff I need to clear from the garage
located in Sydney
pick up preferred
S15
- Standard Coilpacks - $200
- Standard BOV - $30
- Standard S15 Wheels With used KU36 Semis and minor Rash- $500
- Standard S15 airbox No Snorkle $100
- standard JDM ecu $150
- Standard Air Vents x 3 $50 Each
- Apexi Power FC no hand controller - $650
- S14 Tailshaft - $50
- Standard Sr Exhaust Manifold - $50
- Brand new GReddy LS spec intercooler for s15. Unused and still in box. $700 ono
- s15 rear bar in black with a few small scratches and dings. $50
- driver side tail light (altezza - half red and half clear). $50 not neg.
- set of altezza tail lights (3 circles). $100 ono
- brand new alpine type S sub. still sealed in packaging. $100 not neg.
- HKS s15 intake system (arm, pod and clamps) - $150
R34
- Standard NISMO Sports exhaust R34GTT Catback. good condition no holes, no scratches - $300
- 3inch High Flow racing Cat - $150
- Standard R34 GTT alloy Wheels with tread but need replacing - $350
- Stock BOV - $50
Other
Turbosmart Megasonic BOV. good condition less then a year old - $220 (rrp $323 from www.forcedinductions.com/Blowoff.htm)
Exhaust cannon Carbon Fibre Tip
2 1/2 inch Inlet 3.5inch Outlet With Silencer $50
T28 Turbo inlet Snout $50
t28 actuator - $50
T28 Dump Only Split pipe- $100
Photos available on request
most of the prices are firm
please pm :)
Edited by rhino34
https://www.sau.com.au/forums/topic/405320-s15-and-r34-parts-random-parts-syd/
Cells, what cells.. Lol its a "super hi flow" ;) it came with the exhaust i bought from one of the member inferno something... i believe its a catco...
http://justjap.com/store/product.php?productid=18168&cat=275&page=1
i cant send u a mms of it if u pm ur digits :)
  • 1 month later...
Updated list.. Make offer guys :D
R34
- Genuine NISMO Sports exhaust R34GTT cat & Catback. good condition no holes, no scratches - $300
- 3inch stainless steel Decat (believe to be catco) - $50
- Stock BOV - $50
S15
- standard s15 radiator $50
- Zenon lights + balasts one with high/low in.same.globe $50
Random
standard EPA approved Cat (r33)
t28 actuator - $50
  • 1 month later...
  • 3 weeks later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
