hey guys an girls my mates got a few things laying around for your 34 ;)
r34 stock L/H and R/H white fenders in good condition $100 for both
r34 stock front bumper in good condition $110
r34 fuel pump (nothing wrong with it, I just upgraded) $60
r34 fibre glass eye lids in white $30
r34 screamer pipe and front pipe (BRAND NEW NEVA USED!) $350
BOSS amp 150x4 watts 2OHM $80
all prices are negotiable if interested just send me a text 0424919451(SAM)
or PM me an ill pass it on to sam
got a few pics but not of all items at the moment will post others later when i have pics of them
cheers XD
post-89057-0-63535600-1343295210_thumb.jpgpost-89057-0-95165500-1343295265_thumb.jpgpost-89057-0-98109100-1343295303_thumb.jpgpost-89057-0-30924700-1343295408_thumb.jpgpost-89057-0-98443500-1343295577_thumb.jpg
https://www.sau.com.au/forums/topic/405649-r34-gtt-parts/
hey guys im also putting up for sale a rb25 turbo kit thats brand new never used an im still waiting for it to be delivered sometime this week, im selling as i have decided to go with a different setup.
DESCRIPTION: rb25 r32 r33 r34 skyline t67 turbo charger kit
this comes with the following items
-rb25 t3 stainless turbo manifold
-t67 turbo charger .83ar (good for 500-550hp)
-godspeed gt-series 38mm wastegate (set at 7psi , comes with 11 psi ,15 psi spring )
-Oil line kit , oil feed , oil return (with all fittings )
-2.5" v band clamp set ( for custom make downpipe)
-this is a basic set up, this set up require an intercooler , and intercooler pipe and blow off valve to make it complete
TURBO SPEC:
SUPER T3 T67 TURBO CHARGER .84ar TWIN SCROLL P-TRIM
Intake: 4 inch
Outlet: 2.5 inch
Compressor trim: .70 ar
Compressor Wheel diameter: 57.89 /72.95
Turbine Wheel diameter 54.47 /83.16
Exhaust Trim: .84 ar
Twin scroll turbine housing (quicker response then single exhaust outlet )
Turbine flange type: T3 flange
Down pipe flange type: 2.5 inch v band
Cooling type: oil cool only
Horsepower rating: 500HP
post-89057-0-62844200-1343542276_thumb.jpgpost-89057-0-60130600-1343542290_thumb.jpgpost-89057-0-90027200-1343542306_thumb.jpgpost-89057-0-82766300-1343542324_thumb.jpg
https://www.sau.com.au/forums/topic/405649-r34-gtt-parts/#findComment-6464521
hey all
eye lids are sold
turbo kit is sold
what is still available is
post-89057-0-92912500-1343748775_thumb.jpgpost-89057-0-63829600-1343748809_thumb.jpgpost-89057-0-24496100-1343748845_thumb.jpgpost-89057-0-04411700-1343748909_thumb.jpgpost-89057-0-61827600-1343749052_thumb.jpg
https://www.sau.com.au/forums/topic/405649-r34-gtt-parts/#findComment-6468622
Hey mate is it too much trouble to get a picture of one of the fenders? I just need to make sure it matches mine, otherwise I am interested. Thanks.
Too late, ive bought both of them sorry
https://www.sau.com.au/forums/topic/405649-r34-gtt-parts/#findComment-6472532
hey guys still have:
https://www.sau.com.au/forums/topic/405649-r34-gtt-parts/#findComment-6476543
  • 1 month later...
hey guys i've still got these available for purchase :)
cheers kim
https://www.sau.com.au/forums/topic/405649-r34-gtt-parts/#findComment-6529545
  • 2 months later...
hey mate its white an as far as i know its the stock GTT front bumper if you text my mate as his the one selling it im sure he'll be able to tell you
his number is 0424919451
cheers kim
https://www.sau.com.au/forums/topic/405649-r34-gtt-parts/#findComment-6651018
  • 4 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
