Hey guys, I've searched here, google and eBay looking for the black pipe/hose going from one cam cover to the other on an R34 RB25det. Happy to buy even a universal silicon hose piece but seem to find that either. Guess I'll try a bit harder but in the mean time does anyone have a source for these? Would heater hose be ok for now? (mines gone rockhard and split really bad)
Any hose store?? Theoretically heater hose 'should' be ok, as it's mostly air with just a bit of vapour. But really you should get some proper oil control hose. I get mine from Hoseco. Otherwise Enzed, Pirtek, etc. etc.
Just go in and ask for 5/8 oil control hose.
heater hose wont work as the vapours going out of the rocker covers are hot and the hose will crap itself, as the hose is shaped your best bet is to get one from nissan,or you COULD get one from hoseco but you may have to buy a metre of it unless they have some leftover off cuts
Heater hose will work as a temporary solution is what I meant.
You don't need to use the formed hose, you can rotate the breather to suit any hose. No point paying out the ass for pre-shaped hose. You can also buy half meters from Hoseco. At $18 a meter it's not too bad.
Edited by Hanaldo
So is Siicon hose suitable for this? I can get the piece i need from Nizzbits for $35 delivered so I can use silicon and get it for 18 a meter like u said. Although I do like fitting genuine parts where I can.
go the genuine part if you can, the hose you can get from hoseco may or may not posses the heat resistance that you need. . .as a GUIDE i paid $18 for a breather (from rocker cover to rocker cover) hose for a R32 RB20DET from NISSAN. . .yes you can use heater hose as a very temp repair but why not fix it properly the first time?
It says it's for a RB20DET but those cam breather hoses look the same to me as RB25DET's as well (confirm the part # to be sure). http://www.kudosmotorsports.com/catalog/nissan-hose-blowby-genuine-nissan-skyline-r32-gtst-rb20det-p-581.html
whats wrong with heater hose? ive had it on my 34 for about 4 months now since i noticed the old one had split and i cant say ive seen any ill affects at all, ive taken it on and off half a dozen times since then as well, never had any troubles or noticed any wear or anything.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
