okay i have a R32 with a RB20DET and before putting it in the shed it was running mint didnt miss a beat.
And its been almost 2 years and iv gone to start it and found it very hard to start and when it did i had to hold the throttle on to keep it alive and is coughing and spluttering, high fuel smell from the exhaust.
I changed the plugs and drained the fuel and added fresh stuff in and it didnt help.
Checked spark all good.
so i started to pull the plugs off the coils to work out what cyls are down and i believe at least the first 2 are not going and even maybe the 3rd as well. As there was really no difference with the coil unplugged.
have i got clogged injectors? or some thing deeper?
They are Sard 550cc, they were installed about 3yrs ago from new.
Needs a good flogging most likey be injectors of
If
Loss Of compression Dryed valve stem seals
  • 2 years later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
