  • SORRY I THINK I POSTED THIS IN THE WRONG SECTION
  • 245 REAR WHEEL KILOWATTS
  • BLOW OFF VALVE
  • FRONT MOUNT INTERCOOLER
  • FC COMMANDER COMPUTER
  • APEXI BOOST CONTROL
  • NEW HEAVY DUTY HIGH FLOW RADIATOR
  • HEAVY DUTY CLUTCH
  • TURBO TIMBER
  • NEW ADJUSTABLE PEDDERS COILOVER SUSPENSION RECENTLY DONE (3MONTHS OR SO)
  • FULL NEW POWER STEERING RACK AND PUMP
  • DECENT STEREO WITH FRONT SPLITS AND 12 INCH SUB
  • RECENTLY DYNOED WITH PEFORMANCE CHART
  • CARBON FIBRE BONNET
  • GTR CARBON FIBRE REAR WING
  • NISSIMO LIGHT WEIGHT MATT 17 INCH BLACK RIMS
  • THE MOTOR HAS BEEN REBUILT AND HAS DONE ABOUT 20,000KMS SINCE REBUILD COST IS AROUND $14,000 AND HAVE ALL RECIEPTS
  • GETTING REDYONED THIS SATURDAY THE 4/08/12 HOPING TO PULL 270 KILOWATTS PLUS AT THE WHEELS
  • WILL COME WITH CHARTS FROM UNI GROUP RACING - I HAVE FOUND THEM VERY PROFFESIONAL AND EXTREMLY GOOD TO DEAL WITH.
I PAID 12K FOR THIS CAR LESS THAN 6 MONTHS AGO. I HAVE SPENT A TOTAL OF $6000 GETTING IT RUNNING WELL INCLUDING SUSPENSION AND TUNE AND WILL TAKE 12GRAND CASH.
ITS A VERY GOOD GRUNTY SKYLINE -REALLY MUST BE DRIVEN TO BE APPRECIATED. EVEN ON LOW BOOST AT 200 KILOWATTS SHE REVS OUT NICELY AND HAS SOME SERIOUS POWER AND SOUND.
HOPING PEOPLE HERE ON THIS SITE WILL APPRECIATE A WELL BUILT GOOD ALL ROUND R33. FOR THE MONEY WONT DISSAPOINT. I AM WILLING TO NEGOITATE WITH CASH.
CONTACT STEVE IF YOU HAVE ANY QUESTIONS OR FOR AN APPOINTMENT
0449 636 266
Edited by stevedegs
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
