Thanks man, but yeah I kinda figured that out a few months ago with the help of other guys on this forum.
Basically convinced that it's a 92 as well. This thread just won't let me go back and change the info on the front page anymore...
I wish i had AWD that would be interesting.. Good luck on getting your car done, do you have a build thread?
SO finally I got my rims back from wheelflip yesterday and got my car back on the road
So after a month and a half of her being down i stayed up all night and got to get her running again!
I tell you there is nothing like the sound of a RB starting for the first time, especially when it's yours!
Basically what I did when she was down:
Cleared the sheered off exhuast head bolts
New ARP exhaust head bolts
New SS Braided Brake lines
New SS Bradied turbo lines
New Energy suspension bushings
New Gasket kit
New down pipe
Sealed and check all exhaust and vacum leaks
Cleaned everything!
Installed New A/C system
Cleaned IVAC
Checked and rewired engine plugs
New battery terminals
Grounded the engine and ignitor
Sea Foam Engine Prior to New spark plugs, OIL Filter, Fuel Filter, etc...
And basically just clean alot of old dirt and oil out of her...
I'm sure I'm forgetting a few things. oh well...
914117_10151672813144236_2018269639_o.jp
913988_10151672814284236_2058502250_o.jp
Basically spent alot of cash on parts just to refresh her and took time just to get her perfectly running again
I want her to be around for a long time
And even though I have another engine going in her I still have plans for this one
So now I'm taking the day to just see what else I need to get done and take the weekend to enjoy her
Money is alittle tight this month so I need to still get tires for the other set of 350z wheels.
Well back to work...
#Jswljones#Jswljones
Ok so interesting day today, might be getting the engine early!
I'm talking to my guys about that and designing the plan as we speak so more on that later...
And in other news talked to my buddy ray at the Nismo Shop and they still don't haven't heard anything yet on if they can get parts for my car from japan, he's putting another call in for me so hopefully i can get the windows fixed atleast!!
Another buddy of mine came by for me to test fit his rims!
They are some VIP classic Leon hardiritt ordens wheels with polished lips machines faces.
Here are the specs:
Front 20/10.5 +2, 3 1/2 lip
Rear 20/12.5 +2, 5 1/2 lip
I loved them! And they sorta fit... I would have to do major body work and it's not really out of my range but it's also something i really have to think if i want to do again. It took me a year and a half to get the Supra widebody right.
399528_10151097830259236_1281123125_n.jp
422282_10151097830359236_1861464133_n.jp
405449_10151097830519236_2114477128_n.jp
I really want these though so i gotta do some homework...
well see...
anyway to the rest of the day..
I filled the missing section of the bumper which took about another 4 hours, mostly drying time for the fiberglass and bondo/ paint.
First I started by making a plug to hold the fiberglass. I did this by making a template of the shape of the lip then transfered it to a piece of florist foam that i picked up form a 99 cent store around me. Walmart has this stuff also.
Take your time with this but remember this dosen't have to be perfect.
405357_10151097830844236_1491621180_n.jp
540232_10151097830934236_1007499376_n.jp
Then i cut out fiberglass sheet to approximate size and layed out everything before i started. I also identified weak and cracked spots around the bumper to repair and cut smaller pieces for them.
I them coated the fiberglass lip with resin first and them layed the fiberglass cloth down. then i inserted the plug and continued to coat the fiberglass.
Then I let everything dry for a bit and sanded and bondoed everything down till it was nice and smooth. After that just sprayed it black to cover and protect everything. I did leave the bottom metal bracing though just because it added strength and it wasn't noticeable.
530129_10151097831544236_1276841033_n.jp
580863_10151097831614236_1578580184_n.jp
578849_10151097831704236_1876286197_n.jp
Bottom of the lip where the metal bracing is
185421_10151097832039236_1299031138_n.jp
Test fitting
ALL DONE!! for now...
540315_10151097832689236_1684709080_n.jp
603564_10151097832889236_2115338650_n.jp
I have suspension planned for tomorrow then brake and some other upgrades for the rest of the week!
Hi What is the brand naame of the front Caliper Spacers to take 320 discs and were did ya get them and how much dosh. Thanks Jamind
PM'd you with the answer but for everyone else that might be interested the version that I like is this one : http://www.ebay.com/itm/S13-S14-BRAKE-ADAPTER-UPGRADE-300ZX-Z32-30MM-CALIPER-WITH-12-75-350Z-ROTOR-/271195434777?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2481ef19&vxp=mtr
Not sure if they are the exact same ones but the look almost the same.
I got my set up from Zilvia from another memeber hense why I ended up with 2 different set to try.
You can read the DIY here: http://www.skylinesaustralia.com/forums/topic/423144-350z-g35-track-brembo-rotor-adapter-install-on-a31-cefiro/
The 2 types work the same just basically comes down to where you like the caliper to sit depending on the look your going for.
I actually have the second type still if anyone wants to buy them.
Feel free to ask any questions, I'm more than happy to help.
So since I had a little leak from the broken exhaust stud in my head here is my solution to fix it...
200129_10151392395382085_1014541764_n_zp
312099_10151392395212085_433013216_n_zps
379729_10151392395077085_1730745950_n_zp
484657_10151392419382085_1922024565_n_zp
484854_10151392417987085_86551188_n_zpsb
969074_10151392418537085_55298107_n_zps2
...I need help.... :whistling:
This is why I'm broke....
And if your keeping track...
The car was orignally RB20, I have a Rb25 in the car now...
Yes this is a RB26 and Yes I'm still building the RB30 as well...
LOL all for this same car....
And No, I don't know whats wrong with me....
Edited by Jswljones
My fuel & air upgrade, all this for $100...
Z32 MAF and Remaned 650cc A46-00/ JEGS Injectors
A little Birthday present to myself...
But sadly the injectors might have to go back considering the guy never sent the flow sheet and these are supposed to be reman 650cc units that I've never seen before...
They all seem to be in brand new condition and look great but still the fact I got them so cheap and the tips aren't what normal units look like I don't want to pay to get them flow tested just to find out that they are 270's and be SOL...
I'm not risking my engine no matter how good the deal is...
Anyone ever see these type of tips before??
I've only seen injectors with 4 holes that are OEM re-drilled...
well we'll see...
977910_10151711650704236_1206136951_o.jp
967275_10151711650844236_1037818084_o.jp
965451_10151711650884236_1232555095_o.jp
Oh yeah I also might have found a temp fix for my exhaust leak issue on my heap, gonna try it out this weekend so we'll see how that goes...
maybe I'll get to drive while the 26 is getting shipped over
UPDATE!!!!!! SWEET! The guy basically said sorry dosen't have the flow sheet as listed and refunded my money, told me to keep the injectors!!!!
I basically got them for free!!!!!
I'm just going to send them in and get them flow tested myself!
AWESOME!!!!
  • Like 1
OK so a f**king miracle has happend... I fixed the exhaust leak in the RB25....
It was the most ghetto fix but it worked! LOL!!!!!
I pretty much said f**k it last night and did a hell mary fix with some exhaust putty weld and a new gasket.
I placed some on the inner ring, surrounded it with ATV gasket seal then sandwiched it together...
Waited 24hrs for it to set and it worked!!!!!!
... I basically thought of this bacause I know i'm going to either have to buy a new head or get those other broken studs drilled out anyway so why not right...
If I can drive my car while the other engine rb26 is being prepped it would buy me some time...
Well it f**ken worked! I can't believe it...
Also I've used this stuff before on a friends car that we were selling and it's basically like JB weld. It can be sanded or peeled off... just look for reviews and the cheapest stuff you can find...
Here is a pic of how she was tonight! and a video!
She was leaning out before max boost! LOL! I need a tune and to put in bigger injectors now... :P
Not going to but she needs it.. I have them... we'll see... I might get bored... .... .... maybe .... LOL!
Link to video: https://www.facebook.com/photo.php?v=10151730327724236
966979_10151730327824236_1959507669_o.jp
Also I painted my bike this weekend!!!!
Here is a teaser shot I'm still putting her back together!
Mixed the paint myself, black with gold pearl and copper flakes...
ZX10R
921001_10151725983714236_1120778235_o.jp
Edited by Jswljones
RHD Problems.... my door opens on the same side I park my bike but I don't trust anyone else parking next to her....
How do I make all my cars fit.....
LOL!!!!!!!!!!!!
Well finally got my bike finished today but thats about it... just thought you guys might like a look
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-prn1/1012360_10151732703894236_995142465_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/995825_10151732705224236_711221455_n.jpg
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-ash3/1014526_10151732913769236_414445157_o.jpg
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash3/1014861_10151732913849236_1501401541_o.jpg
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn1/705036_10151732913934236_1224465484_o.jpg
https://sphotos-a.xx.fbcdn.net/hphotos-frc1/1009145_10151732914004236_306638735_o.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-frc1/1009534_10151732914064236_1008359575_o.jpg
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash3/705255_10151732914119236_1451539136_o.jpg
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-frc1/1008202_10151732914194236_1424712076_o.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash3/1015224_10151732914384236_611565303_o.jpg
https://sphotos-a.xx.fbcdn.net/hphotos-ash3/1015528_10151732914489236_1233849576_o.jpg
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-frc1/1015804_10151732914659236_1097738766_o.jpg
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash3/474986_10151732913719236_1914843918_o.jpg
I custom made a tip for My bike which is basically just a tip right after the servo buterfly for the factory motor which i disabled also but I think I'm going to turn it into a manual EVC so when I want to I can quiet the bike down like when I come home and open her up on the freeway.
But it's loud and sounds like a true MOTOGP bike!
I love it!
Well I'm beat, Hope you guys like it.
Edited by Jswljones
  • 2 months later...
Just cause I haven't updated in a while...
Been actually busy with work and waiting on goodies from JDMland...
Also since she is working right now I kinda don't want to mess with her...
So here is a pic that got taken from a local meet... First time I ever took here anywhere...
People were kinda surprised around here to see her, well the people that knew what she was... HAHA!
1119960_10101043543557447_1475269760_o.j
  • Like 1
  • 1 month later...
So I figure I'd do a little update...
I ordered a bunch of parts from JDMland but shipping is taking forever so the wait continues...
I am getting random parts here and there but not everythign to start working yet.
I did get a few other goodies since the last time I've updated here... Thanks Nic!!!
1239110_10151943174489236_1646487618_o.j
1265269_10151943173984236_334523172_o.jp
1276877_10151919091584236_813114904_o.jp
1264891_10151919091344236_1595174721_o.j
980563_10151919091199236_1360840062_o.jp
1243179_10151919090979236_729180555_o.jp
1271575_10151919090874236_2079760285_o.j
But I did get to check out this gem that I used to own...
1263970_10151914582934236_690795717_o.jp
1175149_10151914583014236_1173377905_n.j
1278066_10151914542609236_1344777749_o.j
1267021_10151914542354236_1722430473_o.j
602811_10151914583379236_1310280998_n.jp
Yes that a is a GZ20 Toyota Soarer TT with a 1G-GTE
I used to own one back a few years ago, I miss my car and it was nice to see one again.
Very rare here in the US, when I owned mine there were only 4 that I knew of in the whole country and this one is the very first that has been legalized fully not just in the state but for the country!
And side note, if you can get a car legalized in the state of California it is then legal for the country because we have the strictest laws here.
FML I know....
As for what happened to my car?
it was totaled in a car accident in 2007, rear-ended in LA traffic while I was stopped... thats right going 0 mph... truck ran right into me...
I would have never sold mine...
The owner used to work at Toyota in Japan and with TRD.
Really nice guy and had some great stories. Great day!
But I did get a new toy to play with while I wait for the engine parts.
555914_10151998398539236_1494094296_n.jp
Say Bye bye to the Blitz 01's!
1385581_10151996580219236_1581169709_n.j
1379820_10151996580394236_523396234_n.jp
1377278_10151996580504236_1073030202_n.j
1381286_10151996580639236_1713596543_n.j
Gotta say I have to change my whole suspension set up again with this set up but the new tires feel great!
Alot more comfortable driving but alot harder to get loose so more playing...
Well see what happens but as for this weekend all eyes are on FD Irwindale this weekend so that will be fun...
Found a few pix of my old GZ20... I miss my old baby... RIP...
can you believe that the insurance company tried to give me only $300 for her at first!
I ended up with $15k for her but damn man... I still rather have had my car!
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
