Speedo cable snapped and I need to get my car registered. I presume it will not pass if the speedometer doesn't work?
Was considering getting a gps speedo instead of fixing the oem one, anyone know the legailities of this and whether it will pass a RWC in Queensland this way?
https://www.sau.com.au/forums/topic/406466-gps-speedo-and-rwcqld/
