Well i tried, i thought i was over the turbo scene and wanting to get into a v8... i was wrong, i miss the turbos and manual so much!
So I have here on offer for swap or sale my vy ss ute.
$15,000
It's a 2002, I'm located in vic.
The ute sits on modified interceptors that were widend with a chrome dress lip. Peders shocks front and back, sssl springs in the rear and ss springs up front. I have lower ones for the front but it sits too dam low, also have spare ss springs for the rear.
It has the ss otr intake upgrade with a k&n filter, extractors and twin 3" xforce exhause from front to back, it makes a hilarious sound!
The auto has had a lot of work done, i have reciepts for 3k worth, it runs 2 settings, one being pretty friendly and the other revs a whole lot higher with much quicker shifts.
Red leather interior, alpine head unit, speakers and amp and a pioneer 12" sub.
It's got an after market sunroof installed and has nicely tinted windows.
I got the ute with full intentions of keeping so as soon as i got it i took it to my mechanic for a full touch up, all fluids etc changed, the tune tested in the auto, a few bits and pieces fixed up as well. It even has service history in the book.
Edited by Stromulux
https://www.sau.com.au/forums/topic/406557-vy-ss/
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
