Hey dudes,
This did once upon-a-time have another thread here, but I figured I'd start a new one, given the new course this is heading.
Some of you will recognize this vehicle, I picked up when I was 19 or 20.
I got it shipped to WA, and was intending to just clean up the 20DET, paint the inside of the door jambs, engine bay, etc black, get the car sprayed, then register it and be done.
I did crack the shits with the car more than once due due to various reasons (uncertainty about the chassis integrity, peer pressure & personal problems)
Around April 2010 I bought what is now my daily driver, and that was largely responsible for me barely even looking at this car over the last 2 years.
Most aftermarket parts I bought for this bigger project were stripped off it in desperate bids to keep the other one up to scratch.
2012 was a pretty smooth year, the motor blew around January, as soon as the 25DET went it, it was smooth sailing, and after a decent sized panel and paint job on it, I can confidently say that car is "finished".
I've been spending a bit more time on this one the last couple of months.
Don't mind the mess, it's been hiding for 24 months. Most of that shit was in/on the car.
Genuine works on the rear make up for the...whatever they are on the front.
The engine bay is entirely stripped out, and has been for some time.
I've been cleaning up some surface rust, removing glue between panels, other bits n pieces.
HICAS has been completely removed, as have HICAS+fuel lines and the rear cradle.
I dropped the cradle about a year and a half ago, and pulled the diff out.
Turned out to be a Tomei, and is now in my daily.
It's 5 stud hubs and R33 brakes also went onto the daily, so it's rolling on 4 stud at the moment.
I've got 5 stud hubs on the way from Japan, along with a set of R33 Brembo's
Basic breakdown of plan.
Powerplant/drivetrain
RB26DETT
R33 gearbox
R32 GT-R rear cradle
Keeping with the standard twin turbo's, at least until it's engineered and registered with the 2.6L, then I might up it to a medium single.
Usual mods under the bonnet, magic mushrooms, solid intake, up the boost, 32 GT-R FMIC, coilpacks, out some kind of aftermarket dump pipes, down pipe, high flow cat and into these.
Yep, they rocked up from Japan a few weeks ago, rear hanger has been modified to poke the tips out at a wider angle :)
Haven't had the time of daylight to take some pictures of it here yet.
Interior
R34 GT-R Seats
C33 Laurel Dash
Gauges (boost + oil press. visible full time, water temp, oil temp, and wideband in the glovebox for the few occasions I'll actually need to look at them)
Bodywork
Old sections of chassis rails chopped out, new sections welded in
Sodablast / wallnut shell blast, inside and out
Full respray inside and out, probably Deep Blue Pearl (R35 GT-R)
Mixed body kit (TBO 1 front bar, Autech side skirts and rear bar) with a similar two-tonne scheme to what I had done to my other Cef.
Big bunch of parts (interior, grille, hubs, air cond.) + kit + brembo's on due in Mid-Oct/2012, around the halfway mark of tracking down all the little fiddly shit I need to finish her off.
I've loosely bolted all the panels back onto it, and it's rolling on bare-essential suspension (very difficult to roll when there's no castor rods on either end and steering rack isn't bolt down very well), I'll probably relocate it again soon, put a bunch of parts into storage, finish stripping the interior, then it'll be time to blast it, then panel and paint, then onto running gear.
I've written a 4.5 page "budget" / List of things I need to finish her off to the goal I'm aiming for, and the pricelist came in at $25'000 - $30'000, so, very long road ahead (that includes some parts I've already bought, ~$7k panel and paint work, $7k on motor, box, mods, etc, new windshield, brand new semi moving parts (master and slave cylinders), etc etc)
Got a few bits of paper to fill out for engineering / rego process with the 26DETT.
That's pretty much it for the entry post.
I did some work on it the last couple of nights.
This is how the intercooler piping inlet/outlet section was cut when I first got the car.
Very sloppy.
I cut that section out from my Laurel halfcut (factory turbo), and got a mate to MIG weld it in.
It needs some bog to fill in the areas too big to fill with the welder, but that's easy.
It's all lined up where it should be (used the fasteners on both panels to line it up before welding, tacked it in, then trimmed it down again)
I did have a pic just of that area after priming to give you a better idea, but my SD card is being difficult again.
Finally here is a pic of the engine bay.
Don't mind all the runny primer, I've only been sanding back area's to clean rust and other funky shit, then spraying rattle can stuff straight over the top.
Haven't found that much rust in there though, there was a fair bit under the brake master cylinder, as you'd expect.
None on the batter tray :)
It'll all go back to bare metal before it gets sprayed.
Bedroom and shed are filling up with parts pretty quickly, I'll keep you guys posted on progress as it slowly happens.
Edited by Nic_A31
https://www.sau.com.au/forums/topic/406621-epic-a31-restoration/
nice, good to see another ceffy build to the list
with the chassis rail depending the the sheet metal folder your metal guy has you may only be able to go as deep as it is wide, eg if its 50mm wide some folders will only let it go 50mm in depth so best to chase that up first for rwc n reg
This will all be done stealth spec. prior to rego. and hopefully stay off the engineer's attention.
And we don't have RWC over here.
Rego car, pay rego each year, that's it.
Only time you need to get inspection is when unregistered or to get a red/yellow sticker off.
Anyway, tonight, mate dropped off tailshaft and gearbox crossmember to suit 25 box A31, pretty stoked.
Slowly but surely.
  • 2 months later...
Pointless update:
So, in container landing this/next week:
TBO1 FRP front bar
Autech FRP side skirts
Autech FRP rear bar
Dash cluster
5 stud wheel hubs (front)
Under tray / splash protector thing
Front running lights / side indicator assemblies
Air-Con canister thing
Series 2 front grille
Manual foot rest
Speedo sender (cable drive for RB25 box)
Next container should have
R34 GT-R seats and a set of Work Emotion CR Kai's [17x9.0 +17]
Still haven't got my shit together for panel and paint redface.png Should probably stop impulse buying parts, but it doesn't make much difference.
What do you lot think:
a) Panel and paint first, buy and fit parts, then buy and fit motor and gearbox
b) buy parts, panel and paint second, fit parts, buy and fit motor and gearbox
c) buy parts, buy motor and gearbox, panel and paint third, then fit everything
101 lines on the budget, 13 are complete. So, it's disproportionately ~13% complete.
Edited by Nic_A31
Couple if surprises with last bunch of gear.
Only my front bar turned up, skirts and rear got left behind in Japan, as did half the other Cefiro kit in the same container for another guy hahaha.
I wasn't too fussed, apparently the other guy wasn't the same, so my supplier dude said something about a 20ft container to get the remnants of both our kits and some other gear over here sooner than the next 40 ?
Anyway, my series 2 grille has chrome on the inside.
Never seen it before (I've owned 3? of these grilles over the years), some weird-ass special edition shit going on here:
Also ridiculously glossy, also never seen, only seen matte finish... ?
Wheel hubs ended up being what looks like Attain.
Haven't checked the bearings yet, but they look good soo far.
"diffuser" / Splash tray thingy is in mint condition.
Turbo Manual dash cluster (did look endlessly for a late model cluster, but couldn't find any Cefiro ones with plugs)
(that's a scratch, not a crack...just went and checked after seeing that, haha)
/end CSB
I think I need more aero parts,
I don't even recall selling you a grille, let alone any chrome, haha.
I'm thinking after it's painted, drop just the motor straight in, then gut underneath it and mount the box from inside the tunnel.
Picked this up this afternoon, still waiting for speedo drive, side skirts and rear bar.
I'll need to hack up reinforcement bar to fit this on.
Contemplating which Cef to put it on.
Dummy fit on daily (couldn't mount it up properly because it bottoms out on the cooler and the reo bar)
Long exposure I took last night waiting for another Cef dude to come pick something up.
Completely pointless and unrelated to this build:
  • 6 months later...
I've been slack, I'll admit.
All I've done in the last 6 months is clean the shed, twice, to make room for more parts....then moved same parts inside.
GT-R seats and CR Kais both showed up in April
Ordering some blue decals for them tonight.
How my bedroom looks these days (I normally move it around every couple of months)
This is on its way from Japan too :) but which Cef' do I put it on...?
Still haven't done anything about panel or paint.
I'm unemployed at the moment and have a good amount of $$ in the bank, if I don't spent too much and get off my arse and get a job soonish I'll be able to smash it all out in one hit.
Soon.....
Mostly Yahoo, a little of local as well. With the YahooAuctions stuff, I use Google Chrome to translate the pages to English and a local business lays down the bids for me, ships them to his own yard and gets it put into his containers.
Usually cheaper than buying local, always ALWAYS in better condition though.
GT-R seats are mint, the build date on the stamps on the CR Kai's is 08/08/2012 and all 4 are perfect.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
