Up for sale is my 1990 Nissan S13 Silvia.
It has an RB25DET Engine and Gearbox Conversion that is fully engineered and roadworthy.
It is painted in a custom Metallic Blue with White Pearl in the paint and Red Flecks. The dash and centre console is also painted the same.
I have recentley replaced the engine and gear box about 7,xxx km ago car is running 10psi and comes with a wolf 3D v4 plus hand controller thats still in the box. Has a 3" dump pipe to cat, 3" strait through cat with a 3 1/2" cat back exhaust.
Large front mount intercooler with 2 1/2" piping.
Bosch 040 Fuel Pump
R32 front cross member
Custom radiator
Custom engine mounts
Custom power steering lines
K&N pod filter
Custom made radiator side tank
OS Giken ceramic puk clutch with chromoly flywheel
Autometre boost gauge
Has 180sx front and back seats
Interior is nice and clean
Pioneer head unit, 6" speakers up front and 6x9 in the rear
Turbo timer
jic height adjustable coilovers
5stud conversion with gtr discs n 4pot calipers up front
with 2pot calipers on da rear
new rims they are 17" light weight oz racing rims
new castor bushes recaro drivers seat
only selling as i need a more practical car
I have spent a lot of money building this car and will be sad to see it go.
$10,000 or nearest offer.
also have the old engine that was in it, spare turbo, loom plus what ever else was left over
Let me know what you have smile.gif may consider swap for another car.
For more info plz call or txt me on 0405 548 812
car is located in bairnsdale vic
Edited by cptfatty
https://www.sau.com.au/forums/topic/406677-for-sale-rb25-s13-silvia-vic/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
