Well its been a while since I posted as have been busy with life in general. As some might remember I posted last year in regards to my Cefiro import which was making around 306rwhp from its RB20DET engine. Well that engine had chosen to expire after 2 injectors failed. Week later replacement engine was in but only cranked over 297rwhp, so i decided to break it in an attempt to get 300+ again(at $500 an engine not such an issue). Well it broke.
Had a sit down and thought, what do I want from this car, lots of power and more response?(RB20's are horribly laggy). So I went for the plunge and installed an RB26DETT from an R33 GT-R. This required some custom work in regards to the sump(now running an 8L sump as oposed to standard 4L).
While more costly in the long run I have alot more power potential. On friday it went onto the rollers to finally get tuned(was off the road since January) and it layed down a rather nice 417.3rwhp @ 1bar boost(14.2psi) with over 1600ft-lbs of torque at 1 stage(will scan dyno sheet sooner or later). The setup isnt to laggy either with peak boost forming at around 4,500rpm and a nice broad spread of power from 5000rpm to around 7750rpm.
This tune is a safe setup due to the stock internals and with more timing I believe even at 1 bar there is still more potential in it.
List of mods to engine are:
RB26DETT from R33 GT-R
Nismo cams(256 or 264 we are unsure but give a very nice idle)
HKS adjustable cam gears
Nismo fuel pressure regulator
Larger Hybrid Intercooler
Custom turbos(equivilant to hi flo 2540's, these have run over 2bar before and still made power on previous owners car)
HKS Dump pipes
twin 3" exhaust
Wolf3d V4 ecu tuned for MAP table
600cc nismo injectors
Custom Fuel Sump
There are other mods such as Twin plate OS clutch and VLT Box aswell as custom tailshaft.
Overall i'm very happy with the results and once my Forged rods(Pauter) and some forged pistons(ares more likely still undecided) go in i plan to fit another fuel pump(depending if I went 044 or 040 1st time round cant remember) and wind up the boost :)
HUGE thanks has to go to Fabs of Extreme Autosport for putting up with not only doing the work on my car but my constant questions, phone calls and changing of mind. Also to Anthony(ND4SPD) and Steve(SST_Steve) with the tuning and other information I have required when Fabs was busy.
Some pictures can be found at http://summoner.perthstreetcars.net/Cefiro/ most of them are older pics of the car but there are some work in progress happy snaps.
https://www.sau.com.au/forums/topic/40684-update-on-my-cefiro/
congrats summoner looks like a real weapon you have there good to see you got some impressive results. cant wait till you wind up the boost further and run a number down the strip :)
good things come to those who wait
cheers
meggala
HKS Dump pipes
twin 3" exhaust
Custom Fuel Sump
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
