So I'm sick of using my iPhone to browse the Internet, about 2 months ago my computer shat itself and I haven't bothered to fix it, but it's getting a bit old.
Every time I start it, it tells me there was a hard disk error and to restart. I am basically computer illiterate, so I've got no idea how to fix it other than putting a new hard drive in it.
I don't want a new hard drive and I also want to keep the stuff that's on the current one.
Anyone got any idea? I'd appreciate it if you did!
Thanks in advance.
https://www.sau.com.au/forums/topic/407085-there-was-a-hard-disk-error/
Tap F8 on boot up until you get to a screen that gives you a variety of options.
The first option should be "Repair Your Computer"
Give that a try
if it doesn't work, get back to that screen and select "Safe Mode with Command Prompt"
Type in "chkdsk /f C:" (or whatever the problem drive is if it isn't your C drive) to run Check Disk to fix the error.
Sorry to say mate but i would be taking advice of what the guys have been writing above. +1 to them all.
If it doesnt repair like "Iamhe" has written, then you will have to get yourself a new one and once up and running place your old one as a secondary, if you are lucky enough that it picks it up then copy your info accross and ditch it.
Hmm actually just read again your using a laptop, take the advice of "sofreshsoclean"
If you do end up having to recover the lost data try Mini power tool data recovery 6.5 for free or Disk Internals (have to pay but should be much quicker). It takes an awful long time with Mini power tool data recovery (about a week non stop for more than 1TB) so be prepared before starting it. Although that obviously depends on the error/s and a bunch of other factors.
Edited by *LOACH*
http://www.zdnet.com...ough-luck/20774
MacBook Pro Retina 1/10 for repairability. :cheers:
But no Mac has ever failed in any way shape or form... at all... EVER.
So who cares about repairability....
Edited by *LOACH*
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
