Hello,
I put my automobile together with the new turbo (<5000km one) from GCG for R34 GTT and noticed i get smoke from the engine bay. I thought it was leaking from oil drain hose so i removed everything, new gasket, tightened everything but still leaking. On closer inspection i can see oil coming out of the bottom of the exhaust housing! This is basically new turbo what can cause this ?
Could it be that it was sitting for 6months in my cupboard and the seal dried out ?
Or is there too much crankcase pressure ?
Or something more serious ?
Please assist!
Thanks
Hey,
Oil drain hose is clear as is the hole, i removed the hose and the metal pipe bit to replace the gasket, o ring and tighten it as i thought this was the culprit.
It's a off the shelf 3076 kit for R34 GTT specifically so straight bolt on.
Not sure if my oil pressure sender is working right but it goes to <1 on the stock gauge after running it for 10minutes.
I fitted the turbo myself to make sure everything was put on well, i did take the manifold to get the studs removed/installed by workshop but they fuarked one of them up! All oil lines were super tight !
You reckon it could be PVC valve ?
Car smells heaps popcorny, oil isnt blowing out of exhaust, just burning off when it hits the outside of the exhaust housing.
Ok so it has something like an AVO turbine housing on it and you're running a 10-12mm spacer to get comp cover clearance on the standard manifold?
Sounds all normal to me. You might have a dodgy turbo on your hands. It would be very unlikely/uncommon to have a new garret core piss oil out like that but you would need to send it back to have it checked.
Judging by your comment on its km age I assume you bought it second hand? If so, give it back.
Yeah thats right i got the standard mani and the spacer. The guy that sold me the turbo sold me all the kit off his skyline, which has some minor front end damage he was a member of this forum. Won't be able to give it back as i bought it many many months ago.
Say i pull the turbo out, remove the exhaust housing and give it to someone to change seals etc (If thats what needs to be done) how much would that end up costing and would this be repairable ? Ill take some photos when i get the chance to pull it out.
Have you seen something like this before ?
Thanks for your help
Yeah some photos would be great.
No I haven't seen anything like what you are describing but without seeing it, it's very hard to say. Oil has a funny way of coming from one place but looking like it comes from another.
If you take the turbo off and there is oil inside the turbine housing, then there is a problem. It's not as simple as a quick rebuild as usually this will cost you more than just replacing the core altogether. Just make sure it's not something silly like a scored copper washer of a weeping oil feed line right up where it feeds into the turbo.
just wondering, if its a ball bearing core, then it would would/should have a restrictor for the oil flow ??
if that restrictor was not there that might cause excessive oil pressure which could force its way out the seals could it?
Hi Ben, just saw this, Very sorry to hear mate. Here is some pics up of the Turbo prior to fitting.
It's a proper garret spec GT3076r kit from GCG with the .82a/r housing and 4inch surge slotted inlet.
It was bought from a member in June 2011 who had a very minor front ender before it had even done 5000kms, which the insurance company wrote off.
I dont think it's serious mate. Current pics may help these guys diagnose. If you cant sort it Cooma Diesel in Fyshwick are the local Garrett rep.
hey richard hows that turbo going? what power is it putting out?
interesting how the wastegate dump returns so early, guess it would be good for making it look more stock etc.. but does it hurt the performance..
when your buying such a crucial component i would not want to compromise on using stock housings and doing that sort of exhaust outlet,
It looks like the cartridge is covered in oil in that pic with the GCG tag.
It's not an oil feed line weeping or something is it?
Where both those tags are pictured there appears to be additional thread on the line connections. Is that suppose to be like that or should it be screwed in flush? May have been like this from when the Turbo was removed. Ben - whats it like fitted?
Hi Mark the turbo when on the 34GTT made 304kw's with the Nistune. This was done by chequerd/status tunning.
Hi guys! Hey Richard im Anton btw ;)
Thanks for the gear by the way sounds good and no issues except that little oil leak, its really minor doesnt use up any oil but because its on the exhaust housing it burns off instantly and the whole car smells like popcorn!
Ill pull the turbo out sometime this week so i can have a closer look and show some photos, hopefully its just a loose oil connection.
Also anyone know where to get some 50+mm long exhaust manifold studs ? No one seems to have them and mine are too short by a few threads.
Ahhh - sorry Anton. :blush: dont know what I was thinking. Maybe those big guns of yours put me off. :ermm:
Plus had few Bens around buying heaps of gear too.
Specialty Fastners in Fyshwick for the manifold studs. Take one with you.
:) Thanks ill check them out, and put them in myself this time! Took the manifold to an exhaust shop, two shops didnt want to do it, the other did it but didn't tighten one of the studs and it came loose when i tightened the bolt so i got an exhaust leak now!
i would recommend getting all those bolts from the dealer..replace the lot. cant go wrong with original factory stuff
you should also get the manifold faced, pretty common for them to be warped.. save yourself doing everything twice.
The actual manifold studs are brand new i think the owner before me replaced them all, but i cant get the turbo to manifold studs from the dealer because they are too short.
You reckon getting the manifold faced on both ends is a good idea ?
i would definitely be checking it and probably just get it done anyway, when i took mine off it was warped, the heat warps it , even your brakes get warped with alot of hard braking and eventually need machining,
i got those extra long manifold bolts from ERD, but a nuts and bolts shop should have some good ones..
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
