Am moving, so need to move some stuff or its going to scrap...
This all R31 stuff
RB30 rebuilt 20 000k's ago, with GTR oil pump, king bearings, nissan head gasket, nissan rings.
$150... ONO
Genuine Nissan R31 radiator, has auto fittings, very good condition.
$50.
Stock air box,
Take it if ya want it.
2 engine looms. $25? ONO
Drivers Rear view mirror. Its the import cast ally base one that swivels, not just the crappy ADM that always breaks!!
$20
TI courtsey lights, the Red and White centre ones. $10?
28 spline rear axle. Not sure which one, but its 69cm from the start of the shaft to the outer bearing.
$20 ONO.
Guys if you want anything, just let me know and offer me something for it... I even take beer as payment!! hahaha
Contact me via PM or
0412957329
Thanks
Rob
  • Like 1
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
