I'm selling my Ikeya formula shifter and digital gear indicator kit. (private sale)
R33 And R32 Gtr Can Also Fit R33 Gtst
Installed and used for photos only, going jerico so box and shifter need to go.
$1650 for shifter kit and indicator kit (over 2k for both new)
email [email protected] or facebook trent hewitson if you dont message here. I dont have pm enabled as it fills to quick.
located in dandenong.
http://www.ikeya-f.c...en_shifter.html
Had a few questions regarding included parts.
It has everything including collars and springs.
There is a lot of mis information about these shifters, if set up right with the collars you will have no issues, can supply English instructions to purchaser.
We have been using these sequential shifters for years, never damaged one box in all that time.
  • 4 months later...
  • 1 month later...
