Up for sale is the set of Lehrmeister wheels I sourced for my R33 skyline build.
these haven't arrived yet and should land in Sydney within a week or two!
Rare, cool looking wheels that'll suit stanced Toyotas or Nissans that want to run a chunky tyre.
Specs:
18x9 +35
18x10 +35
5X114.3
Judging by the photos, condition is fair. Looks to have paint lifting on one or two of the wheels (my other set had this too, must be common).
Hoping to get what I paid for them to get over here.
Price: $1500 ono
I will ship anywhere in Australia, shipping will be $100 Aust wide (NSW would be cheaper)
Located in Liverpool region, NSW.
Will be in my hands within a week or two! Still coming from Japan.
PM me!
Adam.
no idea mate, I'd say around 2 inches. 2nd photo is one of the rear wheels.
If they were in the teens, they wouldn't be this cheap! (nor would I be selling them).
They have landed in Australia! I should have them within a day or two, I'll chuck up more detailed photos too.
Open to offers.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
