lol
probably at the stage where I need to shave it... get some Markos style... might even get some tatts/piercings! ;)
does stop me from getting hassled driving the R though... the boys in blue must think I'm a bit older and therefore more responsible... ha!
Markos my folks were very impressed with ProRaw4... they only came for a bit, watched the bench press then went home and watched the rest on the live feed
so anyway, day 3 of 'dieting'... verdict: its massively gay
did a lighter, high rep, dumbbell pressing session last night... including lots of shoulder work... low rest times and lots of drop sets... my god is it boring!
hardly raised a sweat so went and did some high rep squats to finish... last set was 100kg x 20... fark
The GPC National Push Pull is on Sunday the 18th. Its run on the same day in each state.
Victoria - PTC Frankston
Queensland - PTC Brisbane
Western Australia - PTC Perth
NSW - PTC Sydney
ACT - Elite Physique
NT - Power Pit gym
I have one SA competitor fly in to compete at Vic
Anyone interested in watching is welcome, entry is free
Thats pretty cool, so no benching at the moment?
Just cleans/snatches/squats/front squats/overheads
Pretty much spot on.
Weightlifting is the only thing I'm really enjoying at the moment so I'll try to capitalise on that while i can.
We have a good gym at work, i'll still bench there and do a few other things, but at least i can really work on the basics
at home.
Once i c&j over 140 i might go back to powerlifting
the start of my new setup at home.
I have 250kg to start with, will have to add to that hopefully.
Very cool setup!
I would love to do some weightlifting but need some coaching first (and somewhere to do it)... I power clean/push press often but never even attempted a proper jerk or snatch... I can't even overhead squat properly as my mobility is poor
170kg bench at > 90kg! ... man I have some work to do :(
sounds good
I've resigned my full time position and am going into business for myself so should be able to get to the PTC during the week next year... Hopefully I can split my training so it's twice a week down there and twice up here
I know much more progress could be made training at PTC
What do the numbers in the gloss table represent?
Glossbrenner is a formula calculator
You punch in your bodyweight, weight lifted and it spits out a score. It also allows for age correction for over 40's and gender
Here is a link on my site, its easy to work with
http://www.ptcfrankston.com/glossbrennercalculator.html
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
