ok guys going through the garage got heaps of bits here just want it all gone!!!! buy a couple bits get something free etc
bare r33 shell, front hit, straight doors, all glass, cradle, tank, all sus apart from struts/springs
$150 take it away!!! this will be scraped if not taken soon
R33 PARTS
steering rack $50
clutch/accel/brake pedals/bkts $40
stock dump and front pipe $40
stock intercooler $10
stock intake pipe $5
series 2 silver wing $20
silver mirrors $20 pair
passenger window reg/rail $20
series 1 dash $40
handbrake boot great condition $20
pass window switch $10
steering column plastics $10
hicas ECU $30
s1 front grill $20
elec ariel $20
dash surround $20
air con set up, pump, condensor, lines etc (think its complete) $30
power steer res $10
interior lights x2 $5
parcel shelf $10
fan box for air/heater $10
air con box $10
rear pillar plastics $10 pair
drivers silver tailight 2 inch crack in the clear bit down the bottom $10
black outter door handles $10 pair
inner plastic door handles $10 pair
door locks for central locking $20 pair
steering coloumn controls washer stalk, headlight stalk $20
washer stalk $5
set seatbelts $20
stock castor rods/rear camber/toe arms $20 THE LOT
gear boot/metal ring that goes under the console $5 each
hicas unit $10 each
Stainless high mount manifold, heat wrapped $200
Greddy style intake manifold TB adapter already welded to it 280
80mm Throttle Body to suit ^^^^^ $140 or buy both $380
S14 PARTS
clutch slave cylinder $20
tailshaft $40
diff and half shafts $120
stock blue wing $10
carpet grey $20
RANDOM PARTS
Old school carrozzeria CD player and pop out T.V (with remote) 2 units with dbl din bacrket $40
GFB blled valve $30
Splitfire boost gauge (small) $10
mag wheel clock $20 ($49,95 sticker still on it)
used K&N filter with metal AFM adapter $20
set of small block and big block chev pistons/rods ossible reuse, was for a project $40 the lot
may post smaller items or pick up northern suburbs ADELAIDE
pm your number if you need a pic of something!!
Do you have the centre climate, and air conditioning part I really only need the faceplate of it, from the ntre of the dash, R33 s1 ??
Edited by cashie484
  • 4 weeks later...
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
