ok guys going through the garage got heaps of bits here just want it all gone!!!! buy a couple bits get something free etc
bare r33 shell, front hit, straight doors, all glass, cradle, tank, all sus apart from struts/springs
$150 take it away!!! this will be scraped if not taken soon
R33 PARTS
steering rack $50
clutch/accel/brake pedals/bkts $40
stock dump and front pipe $40
stock intercooler $10
stock intake pipe $5
series 2 silver wing $20
silver mirrors $20 pair
passenger window reg/rail $20
series 1 dash $40
handbrake boot great condition $20
pass window switch $10
steering column plastics $10
hicas ECU $30
s1 front grill $20
elec ariel $20
dash surround $20
air con set up, pump, condensor, lines etc (think its complete) $30
power steer res $10
interior lights x2 $5
parcel shelf $10
fan box for air/heater $10
air con box $10
rear pillar plastics $10 pair
drivers silver tailight 2 inch crack in the clear bit down the bottom $10
black outter door handles $10 pair
inner plastic door handles $10 pair
door locks for central locking $20 pair
steering coloumn controls washer stalk, headlight stalk $20
washer stalk $5
set seatbelts $20
stock castor rods/rear camber/toe arms $20 THE LOT
gear boot/metal ring that goes under the console $5 each
hicas unit $10 each
Stainless high mount manifold, heat wrapped $200
Greddy style intake manifold TB adapter already welded to it 280
80mm Throttle Body to suit ^^^^^ $140 or buy both $380
S14 PARTS
clutch slave cylinder $20
tailshaft $40
diff and half shafts $120
stock blue wing $10
carpet grey $20
RANDOM PARTS
Old school carrozzeria CD player and pop out T.V (with remote) 2 units with dbl din bacrket $40
GFB blled valve $30
Splitfire boost gauge (small) $10
mag wheel clock $20 ($49,95 sticker still on it)
used K&N filter with metal AFM adapter $20
set of small block and big block chev pistons/rods ossible reuse, was for a project $40 the lot
may post smaller items or pick up northern suburbs ADELAIDE
pm your number if you need a pic of something!!
Do you have the centre climate, and air conditioning part I really only need the faceplate of it, from the ntre of the dash, R33 s1 ??
Edited by cashie484
  • 4 weeks later...
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
