ok guys going through the garage got heaps of bits here just want it all gone!!!! buy a couple bits get something free etc
bare r33 shell, front hit, straight doors, all glass, cradle, tank, all sus apart from struts/springs
$150 take it away!!! this will be scraped if not taken soon
R33 PARTS
steering rack $50
clutch/accel/brake pedals/bkts $40
stock dump and front pipe $40
stock intercooler $10
stock intake pipe $5
series 2 silver wing $20
silver mirrors $20 pair
passenger window reg/rail $20
series 1 dash $40
handbrake boot great condition $20
pass window switch $10
steering column plastics $10
hicas ECU $30
s1 front grill $20
elec ariel $20
dash surround $20
air con set up, pump, condensor, lines etc (think its complete) $30
power steer res $10
interior lights x2 $5
parcel shelf $10
fan box for air/heater $10
air con box $10
rear pillar plastics $10 pair
drivers silver tailight 2 inch crack in the clear bit down the bottom $10
black outter door handles $10 pair
inner plastic door handles $10 pair
door locks for central locking $20 pair
steering coloumn controls washer stalk, headlight stalk $20
washer stalk $5
set seatbelts $20
stock castor rods/rear camber/toe arms $20 THE LOT
gear boot/metal ring that goes under the console $5 each
hicas unit $10 each
Stainless high mount manifold, heat wrapped $200
Greddy style intake manifold TB adapter already welded to it 280
80mm Throttle Body to suit ^^^^^ $140 or buy both $380
S14 PARTS
clutch slave cylinder $20
tailshaft $40
diff and half shafts $120
stock blue wing $10
carpet grey $20
RANDOM PARTS
Old school carrozzeria CD player and pop out T.V (with remote) 2 units with dbl din bacrket $40
GFB blled valve $30
Splitfire boost gauge (small) $10
mag wheel clock $20 ($49,95 sticker still on it)
used K&N filter with metal AFM adapter $20
set of small block and big block chev pistons/rods ossible reuse, was for a project $40 the lot
may post smaller items or pick up northern suburbs ADELAIDE
pm your number if you need a pic of something!!
Do you have the centre climate, and air conditioning part I really only need the faceplate of it, from the ntre of the dash, R33 s1 ??
Edited by cashie484
  • 4 weeks later...
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
