G'day everyone,
Would like to get some advice from anyone that has removed an RB26 from a R32 GTR.
Long story short, a mate with a R32 GTR has got problems with a bearing (we think) so the motor has to come out so we can strip it down and find out exactly what it is. Other tests have been done, and we're pretty sure it's a bearing :D
Sooo, this Saturday we'll be removing the motor.
Is there any little tricks that would help us? Looking at it, it's going to be easier to drop the motor out the bottom with the gearbox assembly still attached, then remove the box assembly while it's on the ground etc...
Dropping it out the bottom, will we need to take the plenum or turbo's off?? Can we just take the turbo's off? The plemun looks like a pain in the butt to remove.....
We've got the workshop manual which we intend on using, but you know how it goes, there's always little trick that can save you hours in frustration.
Any help at all would be great.
Jayson
https://www.sau.com.au/forums/topic/40794-r32-gtr-engine-removal-advice-needed/
Hey Jayson
From my exp in taking out engines its probably easier to take it out from the top.
take off the ex manifold and turbos, undo the fmic piping, take out radiator, undo the aircon pump, take out the coil packs or wiring, undo the gearbox, undo the engine mounts then lift it out.
anything ive missed?
also jayson how easy is it to strip down a motor as ill be doing this on the rb30 block i have
Cool,
That's what we've done in the past, but the thing that makes me think about dropping it down is the tranfercase/4WD and front diff stuff, plus it takes a fair wack of time just getting the gearbox off the motor simply cause of the lack of space :D
Hmmm, we might have to take a good look at it etc...
Stripping down a motor is pretty easy once you've got the right tools (for the head etc..).
But you've got to make sure you take the head off correctly so it doesn't warp. Also have a big clean bench so you can lay everything out in the correct order (pistons, bearings, journals etc..), and if you think you may not remember how it goes back on, take a photo of it :)
J
yeah we took mine out thru the top as well, the left front drive shaft pops out easy, the right front is a real bastard. I think the hardest part was the bolts on the starter motor.
took about 4 hours in the end.
ive talked to phile from skyline perfromance he has just done two r32 gtr's in succession and he can do it in about 4 hours now but the first wont be that fast... what id recommend is undoing everything, then undo engine mounts...then rocking the front of the engine up and the take the gearbox off then pull the motor out.... it is so bloody hard to get them out in one piece man....
an engine jack? I dunno what its called but I've seen pics of RB26's being supported by this hydraulic jack looking thing with a long arm.
or you could do it the same way we did my mates V6, a big wooden stump and a 4 small jack stands
Guest two.06l
jackstands are the way to go resting the front crossmember on them and one for the gearbox.you can leave the turbos and inlet plenum on doing it this way.easier to remove gearbox and that bloody"starter motor".
perhaps off topic question: how do you raise a car without a hoist so you can use jackstands to hold up the engine and gearbox??
Also how much easier is it to do the wiring for the engine while under the car, and from above?
Guest two.06l
sorry did not realise he/she did not have access to a hoist
also much easier to wire up and plug in to loom
yeah thats what we used, engine hoist to lift it out the top. they're pretty snazzy, also used it to lift the car when the cheap sh1t floor jack broke :cheers:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
