R33 GTS-4 Series 2 AWD has 132,000kms on its my brothers and we are parting it out everything for sale PM post or txt/ call me or my brother on the numbers below
Door cards and quater trims - 150
Front seats- 200
rear seats-100
drivers side guard (black) -100
drivers door - 150
pass door - 50 has bit of damage
drivers tail light-100
boot lid and S2 wing-150
M spec side skirts (black) - 300
fuel lid - 50
black mirrors (pair) 200
N/A exhaust cat back sounds good stainless muffler - 250
GTS4 diff - 250
axles -150
Gearbox and tail shaft - 700
GTS-4 motor loom and ecu 1000
front hubs- 200
rear hubs -50 each
calipers - 150 for all 4
Heaps more all prices are ono
Deon - 0432474842
Ryan- 0422646961
whats the best price on the motor i dont need loom or head or the turbo no nothing but the bottom end and everything inside the actual bottom end
need motor asap but looking for good price
Do you have the out side b-pillar plastics? Both sides. " the little/ long plastic bit between the front and qourter panel window" message me on 0410717935 or pm me on here please need them ASAP
  • 2 months later...
Hi Mate
Do you have the front drive shafts for sale ?
Thanks
SOLD
How much for the head and loom?
SOLD
front drive shafts hubs rotors SOLD
gearbox sold
front sump and diff sold
drivers window switch sold
door relay sold
fuel lid sold
boot lid sold
boot wing sold
exhaust system sold
drivers window mech and motor sold
cig lighter sold
AFM sold
extractors SOLD
  • 1 year later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
