Hey guys,
Just bought a 93 gts-t r33 from a friend of a friend.
Just wondering how i go about finiding out which year the car was imported to Aus?? It came with no import papers or service records.
I know this bloke owned it since 2001 so was before this year.
Any help would be great!!
Ryan
https://www.sau.com.au/forums/topic/408158-no-import-papers/
