Hey dudes,
I found the following stuff in my shed if anyone wants it
1x PanaSport 18" Rim and tyre - guess is like 80% tread, good for a spare
1x stock S1 intercooler
1x rollerblind boot cover thingo (grey)
2x Stock Headrests
1x stock cd stacker thingy
if i come across anything else i'll post it up
https://www.sau.com.au/forums/topic/408166-few-random-bits-i-found-giveaway/
