Has anyone ever fitted a 18 x 9" +40 on a gts r33 4 doors? i just recently understand what offset is and I dont want to make a quick purchase without checking. Always never satisfied whenever i rush to get things.Hoping to get some feedback. i know this car is hella old but SAU is all i could think of right now!... thanks!
https://www.sau.com.au/forums/topic/408213-gts-r33-4-doors-wheel-question/
Thanks for the reply guys! [was worried i wouldnt get any!]
I forgot to mention for the front it will be 18x8" +38 instead. Am i good to go? *fingers crossed*
Thanks!
BTW im currently using 18x7.5" on all 4 and the looks dont seem to cut it.
im really hoping the abovementioned wheel specs will improve it significantly if not perfect the looks!
Edited by -S-
What's the offset on the 7.5's ?
Any pics showing the current wheel fitment ?
+38 is still a rather high offset even for an 8" wide rim.
ahhh damn! :( i was so hoping the 1 inches reduction will fit... :( will post my current wheel pics later... and im not so sure about the offset but ill take the pic and post it later. [ i didnt understand offset when i got the 7.5"]
thats mine... can i assume that even with 7.5 inches and with a right offset, it will fill my guards as well? or it needs the RIGHT offset? too much negative offset might hit the brake calipers? am i on the right track? :s
Edited by -S-
Too much positive offset may hit brakes, suspension.
Basically positive offset means the rim of the wheel is sitting further inboard than if it were centred with the hub. Negative offset means it is sitting outward from the body of the car.
i always thought the offset determines the wheel lip! so no go for the 18x8" +38 front? ok to be honest i dont need it to be exactly in line with the fenders. i just want to improve the stance of my car. The ones i have on now is like 1.5 inches more to reach the fenders.
Edited by -S-
18x8+38 on the front is pretty weak.
If you want to fill out the guards 18x8/9 in the range of +25/30 will do the job without neeing to do much in the way of guard work or camber.
Hi, what do you mean by weak? Do you think it will rub against brakes , coil overs etc in the front? now my ultimate doubt is... will it fit without any problems?
im pretty sure that 8 inches is still better than 7.5 inches in terms of looks.
i found a 9 inches one with +35 and that will definitely not fit in the front right? so i am stuck with the 8 inches. just need to confirm it before i make the purchase.
Maybe this will help. Call it a 17" diameter wheel
Your wheel has a centre line. Say its 8 inches wide, so your centre line is at 4 inches of wheel in front 4 inches in the back. As seen in the middle pic where it says zero offset. So if you had a 17 x 8 +0 wheel you would have 4 inches of rim in front of the mounting face and 4 inches behind it.
If you had a wheel that was 17 x 8 +25 wheel, it would be like the pic on the left, and you would have 3 inches of wheel in front of the mounting face, and 5 inchs of wheel behind the mounting face
If you had a wheel that was 17 x 8 -25 off set you would have a 5 inches of wheel in front of the mounting and 3 inches behind the mounting face.
So A wheel with lower offset (closer to zero or in the negatives) will stick out further than a wheel with higher offsets (ie more positive of a figure)
Lower offset pushes leaves less rim behind the mounting face meaning more inner guard clearance but less outer clearance, and fills the guards out more, and vice versa for positive, higher offset have more rim in behind the mounting face but moves it away from your outer guard.
Finding the balance is the key between clearing brakes/ suspension and how much body/guard work you want to do due to having lower offsets
If you're lowered too you might consider getting a rear camber kit to level out your tyres to prevent inner tyre wear.
Also consider using spacers if you can't find the perfect rims, even though i have been told they're illegal.
yes after reading it twice i get it... darn... must be tough to find the right balance... screw that... :(
It's taken me almost 2 months to find the perfect set of rims for a good price, it takes patience. Have a good hard look around for rims would good offsets and widths and you'll come up with the goods. Unfortunately sometimes you have to spend that little extra money to get low offset rims like VOLKS.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
