I'm forever wandering through a local Cash Converters (managed by SAUer) looking for Sidchrome and Snap On etc
Newer stuff is good: tired tools rejected.
Snap Ons don't last more than a day (or so) in that store
Discount by manager helps too.
Well due to the testomony of my step dad and you guys. I bought the essentials from repco yesterday. They feel really good. Will try them out tonight.
Also after i bought my new tools, its slowly filling the whole of my stolen ones. Like cake for a chick i suppose haha.
Once again the generosity is overwhelming on here.
My tools are in the house all locked up! This is also the last straw for where im living atm and am moving.
But yes, thank you, i have even put lock nuts on my wheels, in the fear that they will come back. Moved all the remainder of my stuff out of the garage into the living room. I would sleep next to my new tools if i could haha.
Im so paranoid, that everytime the garage door opens that i listen for my car. God knows what i would do to them if they touch my car
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
