Hi all, I fitted my new large 2 piece tailshaft, along with 2nd hand 4.11 diff, I opened diff and cleaned etc, see shaft in the 'what tailshaft do you run' thread. I have a coppermix single clutch which gives gear noises at low revs as its got no damper, but at 120 it feels like being on the ripple things on the freeway, its terrible! The diff felt good and appeared ok when I cleaned it, but it got super hot (70 degrees ish) in under 10 kms driving. Please help I have a trackday in a week!
https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/
The people who made it need to balance it again or possibly the length has been measured incorrectly?
Also make sure your centre bearing is in its natural position.
/\ on the 2 piece the uni's need to be lined up, did it come bolted together?, still if the diff is getting hot may be binding somwhere?, if you need to get to the track maybe just get another diff, did you have the old tailshaft to try as a comparason?
No, my shaft was the donor for centre spigot and sliding spline, It was bolted together when they balanced it, and it was balanced to some crazy tolerance. And uni's were setup to within a thou of perfect. The centre bearing could be lowered 5mm to get shaft perfectly straight, but that shouldnt affect it.
Its very bizzare, I expected gearbox noises to resonate through it, but not a death vibe.
How could anything in the diff be causing this and how could it get so hot?
Its never been shimmed either..
I have my 4.36 diff which is lazy but will get me out of trouble. I will get a genuine good condition shaft sent out today incase it all turns to shit. This is pretty sad though...
How do you mean "lazy"?
Also, interesting on the gearbox noise... How much noise are you getting? Is it just a light sound? (sorry I know it doesn't help your problem but it's related to a similar convo I had this week)
It had been dropped in transit, small scratch mark on flange. But iv narrowed it down. Old diff back in, and its between 115 and 130 kmh. , its doing my head in, diff and box within well under 1 degree. Is a harmonic imbalance plausible?
After checking everything yet again, all angles are perfect, and the vibration is worse at diff end. I was told not a good idea to undo centre loint and fit factory rear half as its not balanced together, but they should both be balanced anyway so ill have to try it. Anyone got any further experience/input?
  • 3 weeks later...
So I had the shaft rebalanced again. This time far more accurately than before. Been running stock shaft, no issues at all. Put on new big one again, same vibration! Anyone got further ideas before I loose the plot??
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
