  • Replies 49
really should be 30 profile rears...
Why's that?
was Taleb tyres able to beat the prices of thewheeldeal?
Yeah mate, not by heaps but every dolla counts plus he's great to talk to so i don't really care for the price difference.
Thought i may as well explain why we went a 255 35.
working off the 245 45 18 rears, a 255 35 20 rear is only 8-9mm larger in diameter, to have the diameter match up with a 30 series profile we would have to go a 275 30 20.
Sean wanted a little stretch, nothing extreme but nothing too fat either so a 275 wasnt gonna suit, a 255 35 20 on the 10 will go perfectly with a 225 35 on the 8.5.
(a 245 35 20 on the rear would have matched the diameter even better, but A, the V35 comes with staggered rolling diameters from factory so this keeps them uniformly staggered, and B, there would've been more stretch on the rear, the 255 stretch will match nicely with the 225 35 front.)
happy to help
staggered diameter is a good look on a tractor, on the street it looks funny. i guess im just pedantic about things like that
Square setup looks good on your 4 door, staggered setup looks good on my coupe.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
