Looking to purchase a set of second hand coilovers to suit my series 2 r33. After a pair for street use and mayb the occasional track day.
I'm from Nsw Central Coast but can travel to Sydney etc. text me 0421791104
https://www.sau.com.au/forums/topic/409385-wanted-coilovers-for-r33-gtst/
You can get brand new BC's for $1165 through Street to Track.....
I am selling my old Teins but I think 34 rears are different.
gday there bevan , how are ya mate , just passing by and certainly can do a awesome deal on a full set of brand new , hsd , hr series , fully adjustable coilovers , height adjustable , dampening adjustment , alloy tops all round and running the same on my full house drift car .
let me know if your interested mate and if there is anything else i can help you out with , dont hesistate to ask hey
regards anthony
btw i am from sydney and more then welcome to pic up anytime , open 7 days , long hours mate .
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
