Hey guys
Have found A new project and wont be needing these brakes or wheels anymore as they no longer suit the application.
The front calipers and rotors are brand new and havent seen one day of work yet..
The rear calipers and rotors have been used for one or two track days, cant remember.. Bought them along time ago.. Still pretty much as new..
The fronts are 6 pot 383mm x 36mm and the rears 4 pot 343mm x 34mm all rotors are two piece..
I bought these from another member on here jagr33 quite some time ago and have never used them since..
They will suit any skyline from r32 to r34 or silvia from s13 to s15. Just need to redrill your front uprights for 14mm bolts, the rears im assuming on all above models are for 10mm bolts
I am chasing 7.5k + post
Ame TM02 wheels as new measuring 18x10 at +15 offset, with achilles 123s semi slicks 1000kms of highway driving on them measuring 265x35x18.. I pretty much put the tyres on and drove from brisbane to mackay then parked it up..
The wheels are perfect with only the minor mark or two from the socket i used to get the wheel nuts on and off.
And yes these wheels do fit the above brake setup underneath them quite easily unlike most 18" wheels
Chasing 2400 for them + post
Anyways please send me a msg or give me a call on 0433549640 or if you dont mind waiting for a reply send me a pm.
All parts in mackay qld, pictures up soon
Cheers spencer
Edited by spenda
They should fit, all you should have to do to drill out the holes where the caliper bracket bolts to the hub to suit your 14mm bolts as he mentioned in first post.
but the caliper brackets will need to be drilled out to 14mm or the bolts wont fit in.
Think about it, why would you need to drill out your hubs / uprights to 14mm if you have r32/r33 or an s (or Z) chassis car?
Because the brackets these brakes come with are to suit 14mm bolts.
Sorry man, the way i read it was that you would have to drill out the uprights (which i thought were the dog bones / brackets), not the hub to suit the 14mm bolts.
If not, my bad.
So yes they will fit.
Cheers.. These ames are the gunmetal grey ones..
Sorry guys both items are no longer for sale as i have found the money to fund my new project elsewhere..
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
