The badge that sits just under the right set of rear lights on most 34's. Where can you get these from? I have looked all over the forums. One suggestion was to contact Nissan directly. After sending many emails to Nissan and going into my local Nissan shop. I was informed that they are no longer available.
Has anyone had any luck procuring these? Or knows where they are available to purchase?
https://www.sau.com.au/forums/topic/409599-r34-25gt-t-badge/
Have you tried eBay? Just Jap have a lot of badges so I'm sure you could find one there. Or of you're desperate contact Jesse Streeter or import monster. Even try the wreckers. I would have though that these would still be quite easy to source.
Have tried Just Jap, have pretty much every badge but the one I am after. Ebay is full of of GTR badges however, I did find the one 25GT-T badge but it was in the UK and they would not ship to Australia. I'll contact Import monster and see what he can do.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
