hey all my car is going in at 1 pm today for a new clutch fan and a service but after reading idk if i need a new fan my local nissan mechanic said that the fan dosnt disengage so i went out and had i play when i start my car its on max and makes like a quite howling but when i put it into gear my hole car gos quite also when i drive its sounds like a quite bus and its kinda hard to turn by hand if ya spin it will just stop 2 blades down if ya know what i mean cheers :cheers:
edit. car dosnt over heat
https://www.sau.com.au/forums/topic/409695-r34-clutch-fan-need-help-asap/
I would suggest you take it to a workshop that specializes in imports mate. They would be able to tell you what is happening within a few minutes as they have prob seen this sort of thing before.
No point in replacing something that prob doesn't need to be replaced.
Sounds like the clutch fan is locked and in need of replacement i guess, the howling means its locked....... How much did they quote you for one?
280 for new fan new fan shroud and a small rocket cover leak
Also dude, it would just be cam cover gaskets..... There is a really funny image on Rocket cover vs Rocker cover but i cant find it, i found one for you to enjoy :D
No offense intended, just helping :)
kk cheers all guess il let them do it 280 ant much
It sounds pretty pricey, if you have the time ring around and get some other quotes just to make sure you are getting the best deal you can :)
lol i neva new that learn sumthing everyday but in saying that its a 34 so there rockets in there some where ha!!
Hahaha i dunno about rockets mate..... Mine does sound like a bit of a jet now though :D
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
