hay fellas
just wondering if any 1 has run 0awg power cable for their amp, from the battery in the engine bay to the boot ?
if so whats the best way to do soo and what problems might i have?
cheers
I have two 0 ga runs no problems.except near fuses panel inside , you have to really keep it clear of pedals and fuse box , remove seats and do it right it must be taped / tied down its big enough to wander , never pass thru metal without grommet ( it fits fine thru factory grommet ) spray silicone and fish tape or old ford antenna works well to guide it , cut the nose at a slant before fishing it make it easier it wont catch on everything , go under the rear seat metal frame by seatbelt but stay clear of those and enter boot carefully a few choices exist but try to cross factory wires at 90degree angles
and engine bay do not cross shock tower and dont use the path the engine fusebox takes or noise will enter , fuse at battery alway it protects the car not the amp
0 ga will carry 300amps roughly max
Grounds must be 0 on battery to frame
And 0 ga on amp end too
Parts ,
Gaffer or black duct tape
Spray glue , spray the floor pan let sit for min then tape the wire down , just tape wont hold it in place
And dont spray glue the wire too or you'll play hell to remove it if you need to later on
zip ties
fish tape or cut off ford antenna. Solid steel kind cut off ball and use the other side as handle
solid connectors !!
split loom to protect on some spots
Grommets if you decide to drill ? Not required if you use factory grommets
snap knife to slice grommet a bit
Quality liquid electrical tape to seal grommet area if required or black rtv , if your careful you wont need it
Spray silicone to make life easy
Electrical tape to tape wire to fish tape
Pass under all frames inside car away from seat bolts /slides and not in the middle of carpet or it will wear thru it or leave lumps
Upgrade battery
And all grounds to alternator / frame
4 ga battery to alternator fuse and alternator to fuse , ground alternator frame bracket to battery 4 ga
easy done
Edited by Carbon 34
so where do i run the cable through ?
is their a spot through my fire wall ?
Hidden Grommet in the corner near accelerator cable , brake cylinder corner you can use the accelerator cable loop on the shock tower to guide the wire around above the fuel filter
Its tight which is why you need fish tape or something to bend and arc thru the hole you slit in it , comes out high above fuses inside the car and takes a while to get the path clear of pedals and fuses cover , dont try to rush it or it could be unsafe under your feet
we are talking about an r34 gtt right ?
because i cant find the grommet you are talking about ! or maybe i have but dont know if its the one your talking about !
can you please help me out and take a pic of where it is.
cheers
cheers
yes Gtt , iphone no photo syndrome damn thing
maybe tomorrow i can take some and post up off pc , the grommet is buried back behind metal bracket thats screwed on in the corner
Sorry got busy
doubt you will be able to see the hole in photos the thing is buried behind brackets and cable and other items
But will try in a littlewhile to jam a camera back in after the batteries charge up
Sorry iphone cant post photos easy
The grommet is behind the bracket buried back in there. Take off the bracket mounted between firewall and drivers shock tower !! you will see it
in the next day or so that fender is coming off my car so I'll post up the photo with laptop
Pretty sure its already online and sau under blitz return flow fmic install on gtt !?
Try the hole in body in the corner under the bracket , if you slit it and run a fish tape it comes out above the fuse block inside
Take off the trim so you can fish it out and guide it away from ( below ) fuse block and gas pedal
Edited by Carbon 34
  • Like 1
hrmm so the braket is mounted on the fire wall in the right hand corner ?
http://www.skylinesaustralia.com/forums/uploads/post-1416-1152600197.jpg
can you circle or high light where i should look.
sorry for the crappy picture
dude its a crappy iphone nothing is simple
See the blue plate
See the cadmium plated ( goldish) bracket with a ten mm bolt next to the grey plug ?
Unbolt that 10mm bolt tip the bracket out as far as you can and look down there is a hole in the chassis about 100mm in diameter with upside down grommet when you poke your fingers in the hole you will feel it
Get a fish tape or heavy coat hanger with a pre bent arc , slit the grommet big enough for a tight fit , spay with silicone , cut 0 ga on a single angle , tape to fish tape so all copper is covered and a bit further back better too much then not enough
Once silicone hits it you wont get tape to stick again
Spray the wire with a rag behind your spray , smear it up and down the wire you may need to do that a few times
Feed wire from engine bay towards back
Fuse it and connect after its finalized in boot
0 gauge can handle aprox 300 amps max for short time , less on hot days , CCA wire less
(Copper clad alloy)
remember if that thing arcs without a fuse ( even with one its still going to throw a huge spark before it blows a fuse ) its going to possibly catch the car on fire !!!! so use care !! tie it down etc
If it hit a metal fuel line instant fire , it will arc right thru the line like a welder
Do not pinch it or coil up the extra wire under carpets , get it set up the way you want and cut off the rest , never splice it back together its bad practice and creates a resistance
expect new AGM battery
And new high output terminals to match
That factory battery will be toast with a big amp
And those factory terminals suck balls and restrict battery options
Update the ground to engine and frame
0 ga to frame
4 gauge to alternator bracket bolt
At the least
Edited by Carbon 34
failing that theres a grommet up behind the glovebox on the passenger side which is slightly easier to get to =)
Do not run cable across the car stay on the battery side , its bad practice and creates Resistance , plus turbo heat melts wires
And it would take another meter or more wire $$
At this point if you cant see the hole and how to run it , go see a pro ,every car has ten ways to get cable into the car , another choice is under the car but that requires a lot of safety considerations and more cash to protect the car and wire from damage
there is a good video on wire protection on the worlds highest scoring car audio comp truck shows the right way to run under a car when you have endless cash ( do not run under the car without watching how and following the same principal idea skylines have a lot of pinch points to avoid)
It passes thru piss easy its only fussy inside the car because 0 ga is so thick you have to make 100% sure its secure or it will pop up while driving
Or annoy you with a lump in the carpet !!
take the plastic inner guard off from behind the front drivers wheel, or take out like 3 screws and fold it back a little. its a big black grommet with the bonnet release cable running through it. cant miss it
Thanks , but you dont need too do that even
but maybe they can find it that way ??
if not maybe paint it neon yellow and flashing leds! Serious its not hard to see
haha all good boys found it the gommet. the key point is to pull back the guard lining ! u cant see it other wise ! once i did that i run the cable in 15 mins !
and the last system i built i got a 145db with 2 12s running off 2.5k rms on music so i have a little experience with car audio !
cheers guys thanks for the help !!!!
Your welcome
Was that in a skyline ? or ?
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
