hi all
i dont know where to put this , so if its wrong just tell me
i was wondering if somebody could help me out for my school formal, i wanted to go something diffrent to the average limo or falcon, i wanted to go in a skyline r34 or R32 , just love the cars, i was hoping somebody within the brisbane comunity would be able to help me, im willing to hire it or just get a lift to the event ? either way the owner will be driving. if anybody is willing to help or give any advice it would be greatly appriciated
cheers
https://www.sau.com.au/forums/topic/410090-bne-school-formal-hire-or-lift/
hi all
cheers
Send me a PM. My mate has an R32 that he'd probably drive you around in if you came to a hire arrangement :)
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
