My r32 started spullerting as i drive now
It will drive fine then all of a sudden it will glug and then go and glug and then glug a sometimes stall
I have changed
Spark plugs
Fuel filter
Some coil packs as I had spares
Check all hoses
Took off my BOV and put stock back on
Still have it happening
Help! It doesn't seem electrical
https://www.sau.com.au/forums/topic/410136-weird-problems/
It was happening around the low rev range and was also happening alot when I am on slopes
Havnt driven it much since I have changed everything
I took It for a drive before and went up my street it glugged the whole way up and back down
https://www.sau.com.au/forums/topic/410136-weird-problems/#findComment-6550370
Only after the problem happened I didn't touch the car before hand
It's funny you say the ignitor
My car stalled and wouldn't start again a while ago and I decided to change the ignitor and it started straight up but was gluggy as it is now
Could that be ignitor as well?
Didn't think about buying a new one
https://www.sau.com.au/forums/topic/410136-weird-problems/#findComment-6554215
So many things it could be... A few to check/swap/test/clean
CAS
TPS
AFM
Fuel pump
Voltage to fuel pump
Hard to tell as "glug" could mean a lot of things, but if you try all these ^ plus what youve already done you should get somewhere.
Also make sure the spare bits you try are known working, not possibly working. Actually install them on or borrow them from a mates car that runs properly.
Good luck!
https://www.sau.com.au/forums/topic/410136-weird-problems/#findComment-6555717
Yeah I think it's something electrical
Could it be as simple as my battery?
AFM is fine as far as I know
I clean it every month as I change air filter every month
If its not electrical it has to be the fuel pump
https://www.sau.com.au/forums/topic/410136-weird-problems/#findComment-6556008
Its most probably the AFM, the contacts inside sometimes come loose and require resoldering. Do a search if you feel confident, or just replace it with a know good one.
Just looking at a component and seeing it is clean doesn't mean it is working.
https://www.sau.com.au/forums/topic/410136-weird-problems/#findComment-6556258
