I would like to remove the airbag steering wheel and put a sports steering wheel.
Mine is a 1996 GTst with dual airbags.
Is it possible?
Is there even boss kits for the r33 skyline?
Will the computer flip out with error codes ect.?
Or will ir just be a warning light on the dash?
Any links to boss kits would be great also.
thanks
will they know a r33 from a r32?.
and is it a common defect?.
the airbag is not like im hurting anyone but myself hey.
no going to keep standard one incase sorry but i need to know if i change it all back will the dash light go off and all be ok with computer again.
or do i have to get some error codes removed by nissan or something.?
Edited by cosworth1971
series 1 no-airbag model FTW!!! (legal to swap out as i am not removing a safety device)
I dont know how you guys do it. Im 6ft n with the stock wheel i cant see above 40km/h or 3000rpm on the dash!!!!
I put on a steeering wheel that wouldnt look out of place on an xbox :whistling:
can see all the gauges now tho!
boss kits are boss kits for skylines from memory.
U just need to make sure you get one that is 'hicas compatible' so it can run the hicas sensor too
thank you, i didnt even know it had to be hicas.
Now a short boss kit to suit a deep dish wheel?
I want to keep controls within reach but i lurve the deep dish wheels.
pull globe ftw! thanks
You can get a plug in resistor that tricks the ecu into thinking the airbag is still in there. I have a yellow plug in my boss kit.If you knew the resistance of the airbag you could put that across the plug and then you will have no warning light.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
