  • Replies 321
Posted Images
i will have my car finished and tuned by then so ill be there
Good stuff mate! Looking forward to it!
Possible for me, got to see if I can switch weekends. Mums bday on Saturday anyway so another cause to get it off!
Good stuff, let us know either way... It's an earlier cruise than usual but going to be a good day!
OK guys, i will be keeping tabs on numbers as i may need to alter a few things based on the numbers we are getting so far, ill make sure car parks are big enough etc -
Attending –
Me - 34GTT - Newy
Chookie - 34GTT - Newy
Ruxis - 34GTT - Newy
M.J.H - 34GTT - Newy
GTR43A - 34GTR - Newy
Tank - 34GTR - Newy
BenRthirtyFour – R34GTT - Newy
Beenowened – R33GTST - Newy
Humbla – R33GTST – Sydney/Coast
RB25 SKYLINE – R33____ - Coast
Gtraaron – R33GTR - Coast
Notorious – S15 RB power - Newy
Gaz/Shufflr – S15 SR power – Newy
{Oo{34}oO} – S15 SR power - Coast
Chad___ - R32____ - Coast
+ 3 R32’s? Details?
Possibly attending –
Jack – R32GTST – Newy
Mitchkip – R33GTST - Newy
If anyone from Sydney wants to join us for a cruise we could probably meet you here -
This is just before the road splits to Old Pac or FWY, there is heaps of room and jusging by the amount of cars we will need it!
I am not sure if anyone is keen but if so please let know. Post or PM to work out a plan.
We can either meet you on the way down and you can join for Galston Gorge etc OR you can meet us after that and cruise up old Pac for pies with us :D
The other thing i didnt mention is 2 ways or walkie talkie thingys, we discussed them before, who has them? I am thinking it could be a good idea to get one if we will be cruising more often.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
