  • Replies 321
Posted Images
Talked to a friend yesterday about the cruise. He's from NZ moved over a year ago and is very keen to see what aus has to offer in the import scene.
My shotgun is taken :P
My brother might be coming with his 1600
Yeah tell him to bring it along for sure! I remember you mentioned it at the last cruise and I am keen to see it :D
good shit kurtis i want to see this new and improved tyre shreading weapon. :yes:
Needs more fuel pumps! :ph34r:
an appropriate sticker for the cruise http://www.ebay.com....=item337c7a44ab
Haha nice find man!
Might drag my ass up from Sydney and do the whole cruise with you guys.
Would be good if you did mate! Would add another 34 to the rather long list now :P I think its 8-9 34's in total now :yes:
I need to move to the central coast if that's the case.
Moar like Sydn33y.
AMIRITE!?
....yeah that was bad.
It was bad, i still LOL'd..... Majority are in Newcastle area surprisingly..... If you do want to come on this one i would suggest just heading to the meet point at Gosford and starting with us from there :yes:
Your on the list mate!
Attending –
Me - 34GTT - Newy
Chookie - 34GTT - Newy
Ruxis - 34GTT - Newy
M.J.H - 34GTT - Newy
GTR43A - 34GTR - Newy
Tank - 34GTR - Newy
BenRthirtyFour – 34GTT - Newy
Kurtis34 - 34GTT - Coast
FeZ25 - 34GTT - SYDNEY :woot:
Beenowened – 33GTST - Newy
Humbla – 33GTST – Sydney/Coast
RB25 SKYLINE – 33____ - Coast
Gtraaron – 33GTR - Coast
Notorious – S15 RB power - Newy
Gaz/Shufflr – S15 SR power – Newy
{Oo{34}oO} – S15 SR power - Coast
Chad___ - R32____ - Newy
Unknown - R32 - Newy
Possibly attending –
Jack – 32GTST – Newy
Mitchkip – 33GTST - Newy
Bens Bro - Datto 1600 - Newy
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
