hi guys, i'm new here and cant find the search button....so, i'm sorry if this has been covered b4
i hav r33 non turbo front brakes on my s13....i went to repco and searched for the brake pads but repco cant match any of the parts on their catalog.....can anyone tell me the part number? i would prefer bendix as my mate can get em for me at traders' price
btw, there's still some meat on the pads but i can hear squelling sound from the brakes and the disc is starting to wear....there's still some meat on the pads but the wear on the discs makes me decided to change em
https://www.sau.com.au/forums/topic/41118-r33-gts-brake-pads-part-no/
I fitted Bendix Ultimates front and back to my R33 GTST and they worked and lasted very well - 8 track days and about 7000 km on the road. My car took DBA 1170's on the front and DBA 1220's on the back. I don't know whether the non turbo R33 would be the same but I suggest you contact Alistair at Powerplay Imports in Sydney - check their website.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
