Hey guys,
Did some cleaning up over the weekend and found some stuff I no longer need.
Parts as follows:
Fuel System:
Bosch 044 pump, 2L surge tank, braided lines and speed flow fittings.
To suit R32 GTSt mounted in the boot. $350
HICAS lock bar:
Lock bar with ends and boots to suit R32 GTSt in very good condition. $50
R32 GTR rear swaybar:
Good upgrade for GTSt and Silvia owners on a budget. $50
R32 rear strut brace:
Good condition, suits Silvia as well. $50
R32/Silvia Castor arms:
With adjustable poly bushes, in very good condition. $100
R32 GTSt Front LCA's:
Straight and in good condition. $100
Rb25det standard intake manifold:
Complete minus injectors. $100
R32 GTSt set of standard rear arms:
All in good condition. $50ea or $200 for the lot
R32 Thick alloy radiator:
Fitted with EL Falcon fans, this setup cooled really well never saw over 90 degrees (track conditions)
This setup suits R32 GTSt with Rb25det fitted and is a tight squeeze. $250 for setup, $150 for radiatior, $100 for fans
R32 Rear seat belts:
Complete set of rear seat belts, as new condition. $100
GENUINE TRUST T67 25g 10cm Kit:
Suits Rb25det, Complete kit, all items are in good condition.
Turbo & Gate have been checked and are mint.
Only selling this setup because I have decided to go bigger.
Some say this is the perfect size turbo for the RB25det and are good for over 300kw atw with mild lag.
Kit inculdes Genuine Trust T67 25g 10cm turbo, Genuine trust high mount manifold, Genuine Trust wastegate, Genuine Trust dump pipe and screamer pipe and Genuine Trust oil lines. $2600
All prices are ono, items located in Wodonga VIC but i am in Melb a lot so i can organise to meet with Melb buyers.
Happy to post anything at buyers expense.
Cheers
Campbell
0421840982
https://www.sau.com.au/forums/topic/412027-reamed-garage-sale/
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
