  • Replies 71
Posted Images
Judging by his ad the Kms are legit as he states any test welcome, original export certificate supplied. It's rare to see dealers or private sellers providing original export certificates - dealers usually wind Kms back.
As for the rays - they can be easily painted a different colour either DIY or powder coated for 100 bucks here in melbourne
Whoops, just saw that the carsales ad identifies is as a 2003 model. In any case, use the attached link to get to the JP centre calculator. Input CPV35-[insert last 6 digits of the VIN number] and you will get the details of the year and month of production.
http://jpcenter.ru/month
Just an additional verification tool in your quest for the new car.
yes that is correct.
Just to let you know though: when you purchase a car, to make sure the kms are genuine you should look at:
1) if they have all the log books, from japan/australia, with full service history from day 1.
2) the export certificate (original not photo copied)
3) check the interior wear/tear - steering wheel wear/gearknob is faded or not?
4) test drive the car - is it smooth?
if you really want to get into the details you can also see if the rotors are lipped/ plenum condition....
if you purchase from a dealer, 99% of the time they won't give you the original export certificate. and 99% of the time they will only supply Australian log book history not the japanese ones.
Cars with low mileage is not unheard of in Japan, public transport is extremely convenient over there and people tend to just use that,
just to give you an idea mate, when I purchased my car (2004 coupe), I went to about 4 dealers here in Melbourne, out of all the "genuine mileage" cars they advertised, they did not provide auction sheets/log books or export cert for any ---------------------------> I wonder why???
Thanks Yun, she drove home like a champion, and I love how it turns heads.
Got a few small plans, but don't think it needs much to be close to just the way I want it - you've done all the hard work!
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
