Hi guys, thought I'd share this with any of the v35 guys first to see if anyone is interested.
I got a few sets of these globes for sale as I bought them in bulk about a year ago to supply to Autobarn and I've got a few sets left.
GENUINE philips items. You can verify with Philips Australia if you want.
These are good for you guys who've had your HID's converted to halogen during compliance but hate the stock yellow lights.
These give off a white light, kind of blue but more leaning towards white. Similar to HID's, way better than the stock halogens.
Each set comes with 2 H1 globes and 2 parkers to match.
$45 bucks each set.
Can ship interstate via registered post too. But I prefer pick up in Melbourne as I just want to get rid of them I have no use for them.
Edited by =CPV35=
Could you verify which bulb the H1 is? I have standard halogens on my 03 coupe and my front top right bulb is buggered and wanted to replace all 4 lights at the front but unsure which bulbs i need to replace with.
Cheers
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
