Hey guys, I'm wanting to buy a new exhaust for my coupe. Been thinking about the Topspeed pro 1 . I want something that's just a deeper sound and a little louder either as little droning as possible :) I know I'm prob asking for to much but just don't want it overly loud. Any suggestions ???
https://www.sau.com.au/forums/topic/412313-new-exhaust-info-plz/
I've been umming and arring about the HKS rep and Magnaflow X pipe whether or not to get it or save more and get the TDX V2 + test pipes combo. I need to hear a HKS rep in person!
What's the price difference, seano?
hey where do you guys usually get the x-pipes from? ebay or?
Statik performance stocks them i'm pretty sure, for around $100 + shipping.
Massive. You can buy the TopSpeed HKS rep exhaust for $400 + $395 shipping, + $150 ish for the x pipe + whatever labour costs to fit the X pipe to the exhaust and whatever modifications need to be done to the exhaust incase it rubs (very common for it to rub against the right side diffuser and melt it) so I'd say a total of about $1300 or there abouts fitted.
Motordyne TDX V2 + ART pipes i just got a quote last night for $2175 delivered including taxes and everything. I'm not sure if i'd get a shop to fit it, i haven't heard much about the system not fitting properly so it could be a DIY job.
Went to mercury motorsports. They said I need to get a haltec otherwise I'd prob lose power from it
From such a reputable outfit it seems strange they would try feed you such b/s.
Cheers for the cost diff. So about half. I like the look of the hks rep / hks. Those looped resonators look mad. Pity you can't see them from behind the car :-/
Mat i'll just correct myself on those prices, i was quoted wrong.. the guy didn't include the ART pipes. It's actually about $2700 for the full MD TDX V2 + ART pipes shipped to your door. I'm choosing to save the money and go for the better quality stuff i have been convinced by the boys that actually own the system and absolutely love it, whereas the guys that have the HKS rep like the exhaust they did f*ck around with fitment and it's not as good quality material as the motordyne products.
They must've been talking out of their organic exhaust pipes. Did you tell them you weren't born yesterday? Wankers.
Perform a fuel relearn and your stock ecu will recalibrate to make the most of the mods within its factory tolerances.
  • 1 month later...
Greetings All,
I know that this may sound stupid,.....but I was wondering if the exhaust in the video, would work in my 2004 V35
http://www.6mt.net/forum/g35-coupe/36145-m2-performance-exhaust-review-hks-replica.html
Thanks for your time!
Yes Art it will.
Keep in mind with this system you will need the Magnaflow X pipe which heavily reduces the annoying rasp that comes with this system. More than likely you will have to adjust the hangers on the exhaust and some modifications may need to be made in order for this exhaust to not rub on the underside of the car.
Statik performance stocks them, Art join the facebook group and get in touch with Henry from Statik performance he can sort you one. TopSpeed HKS rep exhaust for $400 + $395 shipping, + $150 ish for the x pipe + whatever labour costs to fit the X pipe to the exhaust and whatever modifications need to be done to the exhaust incase it rubs (very common for it to rub against the right side diffuser and melt it) so I'd say a total of about $1300 or there abouts fitted. I have also heard that the system in some places may touch the underside of the car causing it to rattle which is very annoying so make sure it's professionally fitted. ALSO make sure you buy OEM Nissan gaskets, you will need a total of 8. DO NOT use the gaskets that come with the system as they leak.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
