hey guys i have a mint condition set of TE37 super laps 18x10 R18 +22 offset they currently have worn AD08s on them atm and require new tyres soonish
anyways i was hoping to jump down to 17 inch wheels instead still want similar size 17x9.5 minimum up to 17x10.5 maximum still want Te37 super laps for now may open up to different wheels depending on epicness of wheels ie BBS LMs or something baller :P wanting to grab new tyres around end of the year if nothing happens to then i will have to sell the wheels for $3000 as they in perfect condition pm me if you have offers apart from buying the wheels ;)
picture for reference if you require more let me know i can give close ups ;) also im located in sydney would prefer someone in sydney as well ;)
https://www.sau.com.au/forums/topic/412325-swap-swap-te37sl-gtr-size/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
