Hi Guy's
My R32 GTR is up for sale, don't really get to drive it any more so it's up for grabs. has a long list of mods and never been to the track or drags Been fully respayed about a year ago. Bought the car off a forum member PhilGTR who did the engine rebuild. Had all the recipts but can't find them at the moment. But will keep looking for them .It has a fully forged re built engine Mods are as follows.Also comes with a set of standard r32 GTR wheels. Bargain at this price. Please note the price is non negotiable, Will not drop the price at all.Very Very quick car. call me to ask any question 0411 574 412.
ACL Forged Pistons
ACL Piston Rings
ACL Big End Bearings
ACL Main Bearings
Ported and polished head
Stock polished crank and rods
Bored and honed Block
N1 Oil pump
N1 Water pump
Tomei Oil Gallery restrictor
Gates timing belt
New engine gaskets all round
New Thermostat
New NGK spark plugs
R34 GTR injectors
GT 28/60 - 7 Turbos
New Rod bolts, welsh plugs
Fresh paint on rocker covers
3" Trust Front pipe and Power Extreme II Cat back Exhaust
3" Metal cat
Twin Apexi Pods
Apexi Power FC & Hand Controller
Greddy Profec B Spec II boost controller
Nismo fuel pump
17" deep dish rims
adjustable cam gears
SARD 600 cc injectors
Splitfire coilpacks
Jim Berry clutch rated to 400kw
im sure there are a couple of others i have forgotten. Car is making 322rwkw and just needs a set of cams to really open her up.
Cheers Guys,
https://www.sau.com.au/forums/topic/412509-r32-gtr-for-sale-14000-sydney/
how much rego left mate? also what year model? does the AC work? any problems at all? im interested just waiting on my motorbike to sell (hopefully this weekend coming) thanks :)
Edited by barnoon
Hi Mate,
It has 11 Months REGO and is a 1990 model, the body is perfect. The only problem with the car is a slight oil leak from the oil return line from the front turbo, easy fix, just change the oil return hose. Also 4WD has been disengaged so only rear wheel drive :yes:. 322 KW at the rear wheels means allot of fun.
Price Drop to 13K but has to be gone by the weekend. Really need the cash.
Guys oil leak is fixed, Took the car to Matt at F&E he said that the 4WD issues seems to be the TPS as the pump is working very lazy. So that's a $400 fix guys, other than that the car is Great. 13K is a bargain!!!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
