Hi
Tried a few searches with no luck
Can someone please let me know what specs I need for the centre threads for the oil filter sandwich plate for a R34 RB25de?
I have two senders (oil temp and oil pressure) to install (both 1/8 NPT), and I have enough junk tee'd off my factory oil pressure sender (turbo oil feed etc). So I would like to use a sandwich plate (and also be able to run an oil cooler later on if need be!).
Cheers
did some research (should have done so first) and found that for a oil filter sandwich plate purely used for sensor attachments, the port orientation doesnt matter - due to the engine oil entering the filter around the edges and returning down the centre fitting.
An oil cooler filter sandwich plate however does have diversion plates etc to make sure there is adequate flow through the cooling system.
here is an image for an adaptor plate with four 1/8 NPT fittings, which is odd because other than oil temp and oil pressure, i'm not sure what you would use the other two fittings for ...
word of advice - if you're not buying a reputable brand oil filter adaptor, check the fittings are tolerance controlled properly. my centre fitting was the correct thread at 3/4 -16 but the tolerance was off enough to start binding when screwing on the filter. when purchasing, ask if you can fit a test filter to confirm the threads etc.
anyway, everything went on fine, I have my sensors in, no leaks, gauges work great. peak and hold functions with warning lights and buzzers. R32's run suprisingly low idle oil pressure ..
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
