ouch how come engine re build, ? what happened? you chucking cams in too ?what else?
time to chuck that thing on e85. ill prob be brining both my stags my mate will be driving one as his is off the road as we do the rebuild, so should have a spare seat if ya keen.
If the date is good...we will gladly join you young folks lol
"them OLD peeps"
BUGGA !!!! ...we are out this Sat is already booked for us..best of luck guys..Enjoy the drive.
"OLD Jules & Mark"
atm i wont be out cause having headlight issues. both sides are not recieving power for some reason. fuses are fine only relay not feeling like it is clicking is the black HID one. any idea anyone? or help?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
